daedalus 434 Posted March 24, 2022 Posted March 24, 2022 Device: TCL C725 Android 11 Appversion: 2.0.70g Serverversion: 4.6.7.0 when playback files with DTS HD audio streams sound is very distorted, including some visible video stutters stats for nerds shows direct playback, but i get no "dts notification" on the tv dts files, direct playback too, play undistorted but there is also no "dts notification" audio playback setting in emby is set to 'auto' forcing software downmix (very low sound on multichannel files) / "fix playback function (what directly transcodes also the video)" for sure "solves" the problem, but then there clearly isn't anymore a dts hd stream to send to the tv decoder via the internal player, files playback normal and undistorted and the "dts notification" is shown there no problems on dolby tracks, "dolby atmos notification" is correctly shown if present
ebr 16337 Posted March 24, 2022 Posted March 24, 2022 1 hour ago, daedalus said: learly isn't anymore a dts hd stream to send to the tv decoder Is the TV hooked up to a surround system?
daedalus 434 Posted March 24, 2022 Author Posted March 24, 2022 (edited) 2 hours ago, ebr said: Is the TV hooked up to a surround system? there is one attachend over 3,5 jack, just 2.1, but its all the same if it's disconnected and just the tv itself Edited March 24, 2022 by daedalus
ebr 16337 Posted March 25, 2022 Posted March 25, 2022 Okay, then you should set the audio option in the settings in the app to "Mix down to stereo".
daedalus 434 Posted March 25, 2022 Author Posted March 25, 2022 why? this does not solve the problem that emby for some reason is not handling dts(hd) streams correctly over to the tv (decoder) as said the files play fine on internal player including the correct detection of a dts stream (notification is shown) and just as a side note, "Mix down to stereo" function is still inferior to then tv inbuilt one, it has low sound for multicahnnel streams and i have the feeling it is a bit muffeled, so having it on all the time is no option and its very inconvinient to check the stream type before and then switch back and forth
ebr 16337 Posted March 25, 2022 Posted March 25, 2022 4 hours ago, daedalus said: why? this does not solve the problem that emby for some reason is not handling dts(hd) streams correctly over to the tv (decoder) as said the files play fine on internal player including the correct detection of a dts stream (notification is shown) and just as a side note, "Mix down to stereo" function is still inferior to then tv inbuilt one, it has low sound for multicahnnel streams and i have the feeling it is a bit muffeled, so having it on all the time is no option and its very inconvinient to check the stream type before and then switch back and forth That option was selected automatically for you in previous versions of the app so this is how it has always worked on stereo systems. It is possible that changing some settings on the TV would improve the use of the bitstreamed audio as well.
daedalus 434 Posted March 25, 2022 Author Posted March 25, 2022 that setting in emby and the general settings of the tv has nothing to do with this issue, not if i would have flipped em all the internal player is working correctly, it's just emby that is not working correctly with one single audio format
daedalus 434 Posted April 2, 2022 Author Posted April 2, 2022 ok, so this can be considered another wontfix thing here
Luke 42245 Posted April 4, 2022 Posted April 4, 2022 Can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
daedalus 434 Posted April 4, 2022 Author Posted April 4, 2022 (edited) 13 hours ago, Luke said: Can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks ! exactly the same behavior on dts / dts hd files and additionally precise navigation with the tv remote is impossible, arrow keys get registered multiple times (randomly 3 or 4 times) some HDR/DV files start its playback "behind" the UI with no notification from the tv that these formats are played atmos audio gets correctly handled over to the TV decoder and shows the notification Edited April 4, 2022 by daedalus
daedalus 434 Posted May 1, 2022 Author Posted May 1, 2022 (edited) ok the here the well known silence from the devs has kicked in Edited May 1, 2022 by daedalus
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 (edited) No, I can't. DTS-HD sounds good on my setup. My soundbar displays correctly when using DTS-X just fine. My soundbar isn't designed to display anything when using other formats of DTS-HD, but they don't sound distorted when played. As far as I can tell they are good also. My soundbar also displays when using Atmos which appears to be working also using both Android apps. The only issue I have with DTS-HD is with stereo after skipping which causes the whole video to stutter using both apps. However, it sounds good if I don't skip. Probably not related and I've opened up a conversation about it elsewhere. Setup tried: Shield 2019 pro Server 4.7.0.36 Client ATV 2.0.70 and standard Android 3.2.47 Codecs tried. DTS-X, DTS-HD 7.1, DTS-HD 5.1, DTS-HD 5.1-ES, and DTS-HD 2.0 Shield -> HDMI -> Soundbar -> ARC -> Samsung TV Edited May 2, 2022 by FrostByte
rbjtech 5344 Posted May 2, 2022 Posted May 2, 2022 (edited) 3 hours ago, FrostByte said: No, I can't. DTS-HD sounds good on my setup. My soundbar displays correctly when using DTS-X just fine. My soundbar isn't designed to display anything when using other formats of DTS-HD, but they don't sound distorted when played. As far as I can tell they are good also. My soundbar also displays when using Atmos which appears to be working also using both Android apps. The only issue I have with DTS-HD is with stereo after skipping which causes the whole video to stutter using both apps. However, it sounds good if I don't skip. Probably not related and I've opened up a conversation about it elsewhere. Setup tried: Shield 2019 pro Server 4.7.0.36 Client ATV 2.0.70 and standard Android 3.2.47 Codecs tried. DTS-X, DTS-HD 7.1, DTS-HD 5.1, DTS-HD 5.1-ES, and DTS-HD 2.0 Shield -> HDMI -> Soundbar -> ARC -> Samsung TV I got around to testing this. I don't have any issues using DTS-HD 2.0 after skipping the video - it plays back normally. The AVR confirms it's two channel as I can see the mapping. I'm on Shield 2019 Pro SE8, Emby Server 4.7.0.34, Client ATV 2.0.70g (via DFA). Edited May 2, 2022 by rbjtech 1
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 @daedaluswhat happens if you disable DTS-HD in the Shield settings (or ATV settings probably will do the same). If I do that then my issue goes away, and I have no more stuttering. I assume it's using the DTS core at the time and everything says it's direct playing with no transcode logs. Will your TCL still trigger DTS when using the core?
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 (edited) 8 minutes ago, rbjtech said: I got around to testing this. I don't have any issues using DTS-HD 2.0 after skipping the video - it plays back normally. The AVR confirms it's two channel as I can see the mapping. I'm on Shield 2019 Pro SE8, Emby Server 4.7.0.34, Client ATV 2.0.70g (via DFS). Okay, it's possible my DTS-HD issue is with SE9 or the lack of DFA and the way Emby is streaming it. I always used DFA when I was one SE8. I need to just bite the bullet and fallback Also, like I mentioned in the other thread. It's not all DTS-HD 2.0, just all 6 seasons of Downton Abbey that I've noticed so far. I've got DTS-HD 2.0 movies which work fine. So it could be a different flavor of DTS-HD 2.0 also. Edited May 2, 2022 by FrostByte
rbjtech 5344 Posted May 2, 2022 Posted May 2, 2022 3 minutes ago, FrostByte said: Also, like I mentioned in the other thread. It's not all DTS-HD 2.0, just all 6 seasons of Downton Abbey Ah ok - I thought it was all - I don't have Downton Abbey to try I'm afraid. I'd be happy to try if you can PM me a link to a single episode ?
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 (edited) 3 minutes ago, rbjtech said: Ah ok - I thought it was all - I don't have Downton Abbey to try I'm afraid. I'd be happy to try if you can PM me a link to a single episode ? PM sent. BTW I gave @Spaceboythe link also and he says it stutters for him also just like everything else he plays with DTS-HD. Though he doesn't have to FF to make it stutter. Edited May 2, 2022 by FrostByte
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 @rbjtechOh, and another thing I can use MX player with it just fine. @daedalushave you tried using MX player as an external player with ATV? I can play DTS-HD doing that also.
ebr 16337 Posted May 2, 2022 Posted May 2, 2022 Can you please send an app log from both of those situations (with DTSHD enabled and stuttering and then with disabled and not)? Thanks. 1
rbjtech 5344 Posted May 2, 2022 Posted May 2, 2022 (edited) So I have no issues playing the DTS-HD 2.0 file via DFA or HTTP.. edit - so the only difference I can think of is :- a) SE8 vs SE9 b) ARC vs Direct(mine is Shield>AVR) - does it also stutter if you playback direct from Shield>TV and remove ARC out the equation ?) c) Is your TV set to Sync with the media Frame Rate in SFN - as this is a 1080i/25 source - Mine sync's to 1080/50 Edited May 2, 2022 by rbjtech 1
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 18 minutes ago, ebr said: Can you please send an app log from both of those situations (with DTSHD enabled and stuttering and then with disabled and not)? Thanks. Ok, I just sent two logs user Rick First, with DTS-HD enabled. Playback was fine until I skipped forward. Then stuttered until I stopped. Second, with DTS-HD turned off in ATV settings. I must have clicked FF 5 times using both remote and OSD and playback was good. SFN says it was direct playing and I assume it was using DTS core?
ebr 16337 Posted May 2, 2022 Posted May 2, 2022 Okay, when you have DTS-HD enabled, Exo is using the Shield's built-in codec for the audio. When you disable it, we route through ffmpeg. So the problem is somewhere in the Shield's codec implementation or Exo's. This is the error spit out as the stuttering is occurring: 05-02 09:29:40.974 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 315587, 228116224561, 228116224956, 89485060062, 480256, 479744 05-02 09:29:41.478 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 339745, 228116727843, 228116728264, 89485563354, 480256, 479744 05-02 09:29:41.980 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 363854, 228117230128, 228117230679, 89486065625, 510976, 510464 05-02 09:29:42.481 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 387925, 228117731603, 228117731965, 89486567104, 541696, 541184 05-02 09:29:42.986 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 412125, 228118235772, 228118236161, 89487071270, 573440, 572928 05-02 09:29:43.488 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 436233, 228118729875, 228118738810, 89487573520, 573440, 572928 05-02 09:29:43.997 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 460689, 228119247527, 228119247950, 89488083020, 604672, 604160 05-02 09:29:44.505 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 485072, 228119755508, 228119755864, 89488591000, 635392, 634880 05-02 09:29:45.012 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 509393, 228120262196, 228120262570, 89489097687, 667136, 666624 05-02 09:29:45.521 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 533830, 228120771290, 228120771769, 89489606791, 698368, 697856 05-02 09:29:46.028 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 557805, 228121268497, 228121278346, 89490106270, 698368, 697856 05-02 09:29:46.534 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 582410, 228121783371, 228121784671, 89490618875, 729600, 729088 1
FrostByte 5454 Posted May 2, 2022 Posted May 2, 2022 7 minutes ago, ebr said: Okay, when you have DTS-HD enabled, Exo is using the Shield's built-in codec for the audio. When you disable it, we route through ffmpeg. So the problem is somewhere in the Shield's codec implementation or Exo's. This is the error spit out as the stuttering is occurring: 05-02 09:29:40.974 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 315587, 228116224561, 228116224956, 89485060062, 480256, 479744 05-02 09:29:41.478 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 339745, 228116727843, 228116728264, 89485563354, 480256, 479744 05-02 09:29:41.980 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 363854, 228117230128, 228117230679, 89486065625, 510976, 510464 05-02 09:29:42.481 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 387925, 228117731603, 228117731965, 89486567104, 541696, 541184 05-02 09:29:42.986 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 412125, 228118235772, 228118236161, 89487071270, 573440, 572928 05-02 09:29:43.488 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 436233, 228118729875, 228118738810, 89487573520, 573440, 572928 05-02 09:29:43.997 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 460689, 228119247527, 228119247950, 89488083020, 604672, 604160 05-02 09:29:44.505 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 485072, 228119755508, 228119755864, 89488591000, 635392, 634880 05-02 09:29:45.012 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 509393, 228120262196, 228120262570, 89489097687, 667136, 666624 05-02 09:29:45.521 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 533830, 228120771290, 228120771769, 89489606791, 698368, 697856 05-02 09:29:46.028 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 557805, 228121268497, 228121278346, 89490106270, 698368, 697856 05-02 09:29:46.534 13193 3189 W DefaultAudioSink: Spurious audio timestamp (frame position mismatch): 582410, 228121783371, 228121784671, 89490618875, 729600, 729088 When I use MX player as an external player it FF with no problem. Would that point toward Exo vs the Shield? Or, wouldn't you be able to tell?
