densterocks 0 Posted March 23, 2022 Posted March 23, 2022 (edited) Device: QNAP TS-364 on Intel N5105 Emby lifetime subscription with Transcoding enabled in the setting. I have tried the latest stable and beta version of EMBY, both fail to enable hardware acceleration, software transcoding only. Is it because the current version doesn't support the Intel Jasper family? thanks. ffmpeg-transcode-10c23cdb-4bfb-4767-9572-116adbf0871a_1.txt ffmpeg-transcode-8695585b-f0ab-415f-8993-626600ef7253_1.txt Edited March 23, 2022 by densterocks
Luke 42239 Posted March 23, 2022 Posted March 23, 2022 HI, yes we are working on adding Jasper support. Thanks.
densterocks 0 Posted March 24, 2022 Author Posted March 24, 2022 Hi Luke! Is there a timeframe when that support will arrive? thanks!
softworkz 5133 Posted May 17, 2022 Posted May 17, 2022 @densterocks Jasper Lake might already work.. ..under the following conditions: You have Linux Kernel 5.4 or later You have set the kernel parameter: i915.enable_guc=2 please see here: https://01.org/linuxgraphics/downloads/firmware Your distribution has the "right" firmware included (to date, Intel couldn't tell us what that means and how to determine) You are using Emby Server Beta or Emby Server 4.7.0 or later
