Exist2Resist 2 Posted March 23, 2022 Posted March 23, 2022 I'm getting an Audio Desync issue with Emby Android TV App on 2015 Shield TV Pro. Only happens with high bit rate content, Dolby Atmos with HDR at UHD resolutions. Latest update 9.0.1 I added EmbyCon to Kodi on the SHield TV and it is not happening in Kodi. Basically the content will play fine for a while and then there is a slight pause in the audio, then the lip sync is gone. I also notice the app stutter a bit when I select to play the same high bit content, where as in Kodi it is instant. This is all running on a gigabit wired network.
Luke 42245 Posted March 23, 2022 Posted March 23, 2022 Hi there, can you try sideloading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
Exist2Resist 2 Posted March 24, 2022 Author Posted March 24, 2022 It's doing the same thing. I think it maybe the Shield TV itself, I don't think it can handle that high of a bit rate. I'm doing some testing over the next few days.
Exist2Resist 2 Posted March 27, 2022 Author Posted March 27, 2022 (edited) I picked up a newer version of the Shield TV the 2019 model to test that it's the shield but I can't find Emby on the play store like I can on my 2015 SATV pro. I'm on the same version software. Edited March 27, 2022 by Exist2Resist
FrostByte 5454 Posted March 27, 2022 Posted March 27, 2022 9 minutes ago, Exist2Resist said: I picked up a newer version of the Shield TV the 2019 model to test that it's the shield but I can't find Emby on the play store like I can on my 2015 SATV pro. I'm on the same version software.
