jlj1950 7 Posted March 22, 2022 Posted March 22, 2022 I noticed ffmpeg runs continuously at about 25% CPU capacity. Is that normal? Thanks
Happy2Play 9801 Posted March 22, 2022 Posted March 22, 2022 Depends if Emby is doing something but no. I currently have no ffmpeg processes on either stable or beta servers. We would probably need to see a server log.
jlj1950 7 Posted March 22, 2022 Author Posted March 22, 2022 This activity seems to involve only one particular hard drive. I notice the first occurrance of "quick-extract-imageseries..." files. There are now 292 of them. A couple of the most recent ones are included. quick-extract-imageseries-15d678b4-af0a-4e35-aa32-533f370b4734_1.txt quick-extract-imageseries-7205b71c-79bf-4d1a-9ad6-f23b66ed9ecc_1.txt quick-extract-imageseries-9ff0e1fc-1f6f-4457-9f17-2f96d99fbd3f_1.txt embyserver.txt
Solution Happy2Play 9801 Posted March 22, 2022 Solution Posted March 22, 2022 Yes depending on your setting this will happen on a scheduled task and/or during scan/new item import. per library option
