Luke 42245 Posted August 13, 2022 Posted August 13, 2022 Hi @Dont1982 are you still running into this with Emby for Android 3.2.62?
Dont1982 8 Posted August 13, 2022 Author Posted August 13, 2022 Yes I am. I had the android app installed for a few hours and it still gave me the same errors. 5 hours ago, Luke said: Hi @Dont1982 are you still running into this with Emby for Android 3.2.62?
Dont1982 8 Posted August 16, 2022 Author Posted August 16, 2022 On 8/12/2022 at 10:25 PM, Luke said: Hi @Dont1982 are you still running into this with Emby for Android 3.2.62? any idea on what is going on. Now the server will not let me go into any IPTC channel. But the iptv's app works fine. Is there any way to get my live tv to work like it should. I have had this problem on and off a a long time now.
Luke 42245 Posted August 17, 2022 Posted August 17, 2022 18 hours ago, Dont1982 said: any idea on what is going on. Now the server will not let me go into any IPTC channel. But the iptv's app works fine. Is there any way to get my live tv to work like it should. I have had this problem on and off a a long time now. Can you please provide a new log example? Thanks.
Dont1982 8 Posted August 17, 2022 Author Posted August 17, 2022 3 hours ago, Luke said: Can you please provide a new log example? Thanks. like i said perfect player works fine, tivimate works fine. Just emby server does this. I cannot even go into a single channel at all now, and my tv shows are getting hung up like the apps don't know what is going on. I have been using the fire tv app and the android app that was suggested an nothing is working like it should. I have reset routers, cleared all cache's, uninstalled, done factory resets on devices and reinstalled apps. It still does it. And now it is doing it on the computer also. But on the same computer I can go to perfect player and switch channels as much as I want. But for some reason Emby will not tune to any iptv channels that I have. But it will tune to the hd homerun channels I have. embyserver.txt
Dont1982 8 Posted August 21, 2022 Author Posted August 21, 2022 On 8/17/2022 at 9:46 AM, Luke said: Can you please provide a new log example? Thanks. I hate saying this but this issue is getting ridiculous. I cannot tune to any channel through emby, all other apps, tvimate, perfect player, iptv provider app, smarters player app. All work just fine for unlimited amount of watch time. here is a fresh log with me trying to watch tv today. with Vpn and without vpn, computer (windows with chrome, Firefox, edge), Multiple firesticks with and without vpn's, android app and On 8/17/2022 at 1:23 PM, Dont1982 said: like i said perfect player works fine, tivimate works fine. Just emby server does this. I cannot even go into a single channel at all now, and my tv shows are getting hung up like the apps don't know what is going on. I have been using the fire tv app and the android app that was suggested an nothing is working like it should. I have reset routers, cleared all cache's, uninstalled, done factory resets on devices and reinstalled apps. It still does it. And now it is doing it on the computer also. But on the same computer I can go to perfect player and switch channels as much as I want. But for some reason Emby will not tune to any iptv channels that I have. But it will tune to the hd homerun channels I have. embyserver.txt 8.04 MB · 0 downloads app. Nothing has changed. Can someone figure out what the heck is going on so I can enjoy my emby again. ffmpeg-transcode-9cc72410-44d5-457d-a4a9-4e48f622ef93_1.txt embyserver.txt
Luke 42245 Posted September 14, 2022 Posted September 14, 2022 On 8/21/2022 at 2:12 PM, Dont1982 said: I hate saying this but this issue is getting ridiculous. I cannot tune to any channel through emby, all other apps, tvimate, perfect player, iptv provider app, smarters player app. All work just fine for unlimited amount of watch time. here is a fresh log with me trying to watch tv today. with Vpn and without vpn, computer (windows with chrome, Firefox, edge), Multiple firesticks with and without vpn's, android app and app. Nothing has changed. Can someone figure out what the heck is going on so I can enjoy my emby again. ffmpeg-transcode-9cc72410-44d5-457d-a4a9-4e48f622ef93_1.txt 1.74 MB · 0 downloads embyserver.txt 7.58 MB · 0 downloads @Dont1982 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Dont1982 8 Posted September 14, 2022 Author Posted September 14, 2022 I have multiple times and for multiple days. It does not help. I am using tivimate now for my live tv and it works flawlessly.
Dont1982 8 Posted September 18, 2022 Author Posted September 18, 2022 @Luke I have even changed iptv providers and it still does this. I have tried 2 different vpn providers. Tvimate works good with the new iptv supplier but not the other. When it does go into a channel it plays for about 10 minutes fine then starts stopping and starting like crazy. I have tried to mimic this on other tv's with emby and they do the same thing. I can have emby on one tv on a channel and tvimate on another tv on the same channel and the tvimate plays flawless. Hope this helps. not uploading any logs because it is the same ongoing issues.
Carlo 4561 Posted September 29, 2022 Posted September 29, 2022 @Dont1982 I'm sending you a PM to see if we can do a remote session. This would allow us to see your issue first hand as well as check connection paths and routes. Carlo
