SamES 1084 Posted March 23, 2022 Posted March 23, 2022 I've tested all the samples that have been provided. They work fine on older models. So, from the evidence so far Only impacts 2021 NEO models Occurring on firmware 1904 and firmware versions prior to this release. I'm not even sure if I'd get a sensible response from Samsung on this one. It is interesting that it works fine via USB.
maxiniedermeier 17 Posted March 23, 2022 Posted March 23, 2022 Yes thats the weird thing Maybe thats a thing with the newer Models because there are some other small issues within the app on the 2021 Modell In my opinion it looks like there were made some changes in the firmware which are not ''well optimized'' in the App 1
staticmotion 4 Posted March 24, 2022 Author Posted March 24, 2022 Yes it's clear it's something that Samsung have to fix. And this will potentially affect more and more models going forward. Do you guys have contact with the appropriate Samsung staff?
Luke 42240 Posted March 24, 2022 Posted March 24, 2022 Yes we have a developer support channel we can contact them with. I don't see much coming out of that though, so we may just have to make sure it plays ok with transcoding.
staticmotion 4 Posted March 24, 2022 Author Posted March 24, 2022 In terms of transcoding then we really need 25i to be deinterlaced to 50p and not 25p. This is going to affect DVD rips and most of those will be 25i and not 25p in a 25i container
staticmotion 4 Posted March 24, 2022 Author Posted March 24, 2022 Should be just a matter of adding "yadif" to the FFMPEG parametres, no?
Luke 42240 Posted March 24, 2022 Posted March 24, 2022 We already do, usually. I'll have to refresh my memory but I think it might not be supported with nvenc. Anyway the diagnostics plugin will let you play with search and replace on the final command line so you can do some experimentation with that and see how it goes.
staticmotion 4 Posted March 24, 2022 Author Posted March 24, 2022 Ah okay, it definitely isn't at the moment for me. Any tips on what to use on the search/replace option? If I'm just adding then how does the search part work? Thanks!
staticmotion 4 Posted March 24, 2022 Author Posted March 24, 2022 Found this post which should do what's needed, but it's not working for me...
maxiniedermeier 17 Posted March 25, 2022 Posted March 25, 2022 So would it be possible to add a 576p Option in the Quality setting to get the most out of the original file. As a little workaround
Luke 42240 Posted March 28, 2022 Posted March 28, 2022 On 3/25/2022 at 2:36 PM, maxiniedermeier said: So would it be possible to add a 576p Option in the Quality setting to get the most out of the original file. As a little workaround Hi, what would that accomplish?
maxiniedermeier 17 Posted March 28, 2022 Posted March 28, 2022 The content is transcoded from 576p to 480p with the option it would play at the original resolution?
maxiniedermeier 17 Posted April 10, 2022 Posted April 10, 2022 Any news on this topic Also am i wrong with the assumption that the video ressolution is downgraded when it's transcoding I could start a new thread in the feature request section to add this function Maybe this would also help with live tv content cause it's also 576p
SamES 1084 Posted April 10, 2022 Posted April 10, 2022 Can you try using the portable version of the Emby server (release not beta) and test with a small library to see if it has the same problem?
Luke 42240 Posted April 11, 2022 Posted April 11, 2022 3 hours ago, maxiniedermeier said: Also am i wrong with the assumption that the video ressolution is downgraded when it's transcoding It depends on the quality setting in the app.
maxiniedermeier 17 Posted April 13, 2022 Posted April 13, 2022 @SamES Yes i will try this the next days. @Luke Yes, but it is set to "Auto" and it's not direct playing on the 2021 Modells so it transcodes to 480p the next best available setting. So if there would be the 576p option it will play or transcode at the original resolution without as much loss of quality.
maxiniedermeier 17 Posted June 8, 2022 Posted June 8, 2022 On 4/10/2022 at 5:44 PM, SamES said: Can you try using the portable version of the Emby server (release not beta) and test with a small library to see if it has the same problem? Sorry for the late update. I have tested it with the portable version of the stable release and theres still the same problem. Right now i have installed version 1.2.8 of the app. If you could make a USB install version to test i could test it. @SamES
Elmah 0 Posted September 24, 2023 Posted September 24, 2023 (edited) Hi, I'm also having similar problem with samsung QN91A. PCM stereo audio is transcoded to aac (when I disable transcoding TV direct streams PCM audio but then audio doesn't play at all). I know TV supports this format because when playing it from usb stick using samsung's proprietary player everything works fine. Could you take a look at the issue ? What is the progress of fixing it ? ffmpeg-remux-ee8024c4-a542-47c6-9c0e-5d8017c7ea63_1.txt embyserver.txt Edited September 24, 2023 by Elmah
SamES 1084 Posted September 24, 2023 Posted September 24, 2023 12 hours ago, Elmah said: Hi, I'm also having similar problem with samsung QN91A. PCM stereo audio is transcoded to aac (when I disable transcoding TV direct streams PCM audio but then audio doesn't play at all). I know TV supports this format because when playing it from usb stick using samsung's proprietary player everything works fine. Could you take a look at the issue ? What is the progress of fixing it ? ffmpeg-remux-ee8024c4-a542-47c6-9c0e-5d8017c7ea63_1.txt 193.82 kB · 1 download embyserver.txt 517.97 kB · 0 downloads If you disable transcoding and get no sound with PCM audio selected then you have just proven that the specific PCM format is not supported. I think from memory it’s the LE variant that is the issue. What happens if you put this file on a USB drive, connect it to the TV and play the file using the TV’s built in media player?
Luke 42240 Posted September 25, 2023 Posted September 25, 2023 You might also want to try the 1.6.4 USB build as there have been improvements to track selection since then (just in case that is the issue). Hopefully we'll have the app updated in the store soon.
