staticmotion 4 Posted March 20, 2022 Posted March 20, 2022 Hi. I've just got a Samsung QN94A TV and have found these problems with Emby (note that I've allowed transcoding of video and audio in user settings): MPEG2 files fail with "Playback Error = no compatible stream". PCM audio is being transcoded. Both 2 channel and 6 channel sound. Both 16 bit and 24 bit. PCM audio is acceptable to the TV, as verified by playing files from a USB stick. My Samsung Q90 TV also play the files without needing transcoding. HDR HVEC transoding fails. The network speed of the TV is around 77mps, so I set the profile to 4K 60 Mbps, i.e. to transcode files above that bitrate to avoid stuttering (Westworld UHD rips are around 40 Mbps and play fine through the network, Crash UHD rip is around 90 Mbps so would stutter). Playback fails with "Playback Error = no compatible stream". I've attached all the logs when just going through these three scenarios. thanks embyserver.txt ffmpeg-transcode-9f193659-04b2-42a7-ad3a-d3c6fabf6bfa_1.txt ffmpeg-transcode-6fe0b9d5-faf5-49c3-abb6-c2abc5325cfb_1.txt ffmpeg-transcode-ba8d5ab9-7216-46ba-b940-96bddbd503d4_1.txt ffmpeg-transcode-ad2de3fc-dc27-49cf-89fe-858fb8d368b9_1.txt ffmpeg-remux-d156d24f-1ae8-41cc-a888-e5f33061275b_1.txt ffmpeg-transcode-ae5a56f1-6d9d-416d-b624-d852ff2c7eb5_1.txt ffmpeg-transcode-185b1641-081a-4f94-8366-3e6e9d8eac36_1.txt ffmpeg-transcode-87a95360-89b1-4b01-83b7-062c2c267b97_1.txt
Luke 42239 Posted March 20, 2022 Posted March 20, 2022 Hi, try setting these customizations back to default: >>>>> Non-Default Encoder Parameters Warning EncoderParametersH264Nvidia.NvidiaPreset: Original: Actual: lossless Warning EncoderParametersH264Nvidia.RateControlMode: Original: Actual: constqp
staticmotion 4 Posted March 20, 2022 Author Posted March 20, 2022 Thanks Luke, that's fixed the transcode errors so at least makes Emby more usuable again! However, MPEG2 files are still being transcoded to H264 - which shouldn't happen. And files with PCM audio are being transcoded to AAC - again, shouldn't happen. cheers
SamES 1084 Posted March 20, 2022 Posted March 20, 2022 44 minutes ago, staticmotion said: However, MPEG2 files are still being transcoded to H264 - which shouldn't happen. And files with PCM audio are being transcoded to AAC - again, shouldn't happen. Can you please attach a new ffmpeg log when this occurs. MPEG2 video files are enabled for DirectPlay on all Tizen models, so I suspect there was a playback error and it has fallen back to transcode to play the file. the ffmpeg log will tells us if this is the case.
SamES 1084 Posted March 20, 2022 Posted March 20, 2022 Actually it looks like this is a 90Mbit file and you have a 60Mbit limit set somewhere which is also causing it to transcode
staticmotion 4 Posted March 20, 2022 Author Posted March 20, 2022 The 90Mbit file problem has been resolved, after Luke's suggestion of resetting the transcode options. High bitrate files are now transcoding as expected. The MPEG2 and PCM problems need addressing. The logs I uploaded in my first message are from demonstrating all three problems. If the multitude of problems is becoming confusing I suggest we start by looking at the MPEG2 problem. There is a Direct Play Error on every file (DVD rips), which are all played correctly from USB, and all played correctly on my Q90. The problem is not within the file(s) or the TV capabilities.
staticmotion 4 Posted March 20, 2022 Author Posted March 20, 2022 The log "ffmpeg-transcode-ae5a56f1-6d9d-416d-b624-d852ff2c7eb5_1.txt" is from playing a MPEG2 file
SamES 1084 Posted March 20, 2022 Posted March 20, 2022 2 hours ago, staticmotion said: The log "ffmpeg-transcode-ae5a56f1-6d9d-416d-b624-d852ff2c7eb5_1.txt" is from playing a MPEG2 file Can we get a new log after you’ve made the changes that Luke suggested as it will change the output? Thanks
staticmotion 4 Posted March 20, 2022 Author Posted March 20, 2022 Will do that now. Although, as transcoding is now working it transcodes to H264 rather than Directplay
staticmotion 4 Posted March 20, 2022 Author Posted March 20, 2022 Logs attached embyserver (1).txt ffmpeg-transcode-786c15d8-e0f3-4bac-b6b3-42b41d8a31d4_1.txt
SamES 1084 Posted March 21, 2022 Posted March 21, 2022 It looks like for some reason DirectPlay in the client is just failing, so it is automatically falling back to transcode TranscodeReasons=DirectPlayError
SamES 1084 Posted March 21, 2022 Posted March 21, 2022 Try putting the file on a USB drive and connecting it directly to the TV and test playback using the TV’s internal player to see if that works.
Luke 42239 Posted March 21, 2022 Posted March 21, 2022 @staticmotion please let us know if that helps. Thanks.
staticmotion 4 Posted March 21, 2022 Author Posted March 21, 2022 Sorry for the delay. MPEG2 files (DVD rips) play perfectly from USB. Fail when played through Emby
staticmotion 4 Posted March 21, 2022 Author Posted March 21, 2022 Fail in the sense that it resorts to transcoding, as above
SamES 1084 Posted March 21, 2022 Posted March 21, 2022 4 hours ago, staticmotion said: Fail in the sense that it resorts to transcoding, as above If you can PM me a link to the file for download, I will try it out
staticmotion 4 Posted March 21, 2022 Author Posted March 21, 2022 I can do SamES, but as every single MPEG2 file I’ve tried results in a DirectPlay error - and all of them play perfectly through the same Emby server on my other Samsung TVs, and on the QB94A through USB - would that actually be helpful? It seems some interaction between the model (and then potentially other new Samsung models) and Emby is causing the problem, not the files themselves
SamES 1084 Posted March 22, 2022 Posted March 22, 2022 12 hours ago, staticmotion said: I can do SamES, but as every single MPEG2 file I’ve tried results in a DirectPlay error - and all of them play perfectly through the same Emby server on my other Samsung TVs, and on the QB94A through USB - would that actually be helpful? It seems some interaction between the model (and then potentially other new Samsung models) and Emby is causing the problem, not the files themselves I think you may have hit the nail on the head. For some reason, this is only occurring on 2021 Neo models. Same problem here for this user. https://emby.media/community/index.php?/topic/106928-576p-videos-werden-transkodiert However, I don't believe this is anything Emby is doing. DirectPlay error is caused normally by the TV's internal player, I don't think it is anything we have control over. Has this always been a problem for these videos on this model TV, or did it work correctly at some time?
maxiniedermeier 17 Posted March 22, 2022 Posted March 22, 2022 I've had the tv for about a year and haven't noticed any different behavior til today
staticmotion 4 Posted March 22, 2022 Author Posted March 22, 2022 I’ve only just bought the QN94A so I don’t know if this has been caused by an update. I’m on firmware 1904 fyi. Do you guys have contact with Samsung engineers and can raise this issue? It’s not only MPEG2 but PCM as I outlined in the first post. I’ll contact Samsung support but I doubt I’d get through to the appropriate level!
Luke 42239 Posted March 22, 2022 Posted March 22, 2022 17 hours ago, staticmotion said: I can do SamES, but as every single MPEG2 file I’ve tried results in a DirectPlay error - and all of them play perfectly through the same Emby server on my other Samsung TVs, and on the QB94A through USB - would that actually be helpful? It seems some interaction between the model (and then potentially other new Samsung models) and Emby is causing the problem, not the files themselves Can you please still send him a sample video for testing? Thanks.
staticmotion 4 Posted March 22, 2022 Author Posted March 22, 2022 Sure, can download here: https://wetransfer.com/downloads/6618de70d9057ae61c410ef2da29889220220322161321/d01ca0c99f10b43cedc7144ff415ec1d20220322161342/f1c467
SamES 1084 Posted March 22, 2022 Posted March 22, 2022 7 hours ago, maxiniedermeier said: I've had the tv for about a year and haven't noticed any different behavior til today Can you please check your firmware version? I've tested a sample here on my older TV and it still DirectPlay's without issue. At this stage, it seems to only affect newer 2021 NEO models based on these two reports
FrostByte 5453 Posted March 22, 2022 Posted March 22, 2022 OP indicated they were on 1904 earlier https://www.samsung.com/uk/support/model/QE55QN94AATXXU/#downloads
maxiniedermeier 17 Posted March 22, 2022 Posted March 22, 2022 (edited) My TV has Version 1904 since mid January In older Versions the problem was also there Just tried App Version 1.2.5 and still the same behavior Edited March 22, 2022 by maxiniedermeier 1
