Press1Now 3 Posted March 19, 2022 Posted March 19, 2022 Hello Everyone, I recently build a new dedicated Linux emby server and got everything working the way I want to. The previous computer was a shared Windows 10 computer I went in server settings and unchecked run server at startup and do not have it running as a server services. I noticed that it's starting up again right before a scheduled recording, yes I still have items in the series recording. I want to keep the Windows 10 setup as a backup but turned off. How do I permanently keep it shutdown ? Again I want to keep it as a back up server with making too much changes. Thanks
Happy2Play 9801 Posted March 19, 2022 Posted March 19, 2022 I don't think it is possible for what you are doing. The schedule recording create Windows Scheduled Tasks for this event to ensure sure server is running/awake. So the backup/mirrored server won't really work as proper backup/mirrored server (to my knowledge).
Luke 42186 Posted March 19, 2022 Posted March 19, 2022 The upcoming 4.7 server release will include an option to not have the DVR create windows task scheduler entries, thus allowing you to skip that. It will then be up to you to ensure the server is running in order for a recording to take place.
Solution Press1Now 3 Posted March 19, 2022 Author Solution Posted March 19, 2022 1 minute ago, Luke said: The upcoming 4.7 server release will include an option to not have the DVR create windows task scheduler entries, thus allowing you to skip that. It will then be up to you to ensure the server is running in order for a recording to take place. Thank you Luke, Any time frame on the release of 4.7 ?
