Audio cuts out
greenhouse
I know this issue has been discussed a 100 times but I can't find the post about it.  Emby theater video is perfectly fine when playing mkv 4k with atmos.  I do have brief audio cut outs for like a half second.  They come in groups.  I will get about 5 to 10 in a 20s period and then fine for 15 minutes then a couple cut outs then fine for 10 minutes and on and on.  I remember reading something about increasing the buffer size to fix that.  How do I do that?
The audio buffer 'workaround' doesn't really solve the issue. I'm pretty sure it has to do with the WASAPI interaction/implementation, as we're using an external device. I'm hoping that when this commit is merged, it will get rectified.
But if you want to try making the buffer bigger, add this to your mpv.conf
audio-buffer=0.5
But first try this test build.
