MSI2017 48 Posted March 18, 2022 Posted March 18, 2022 (edited) Hi all, I've noticed a lot of my stuff not having subtitiles anymore apart from the ones embedded in the files. When going to the library settings there are no subtitle settings anymore. When creating a new library the option is also gone. Has it moved? Edited March 18, 2022 by MSI2017
Happy2Play 9801 Posted March 18, 2022 Posted March 18, 2022 Can you post a server log? What client are you using and how are you connecting? But no it is still there on my 4.6.7.0 and 4.7.0.31 servers.
pwhodges 2025 Posted March 19, 2022 Posted March 19, 2022 As I understand it, in order to see any settings you have to install one of the subtitle plugins first. Paul 1
MSI2017 48 Posted March 24, 2022 Author Posted March 24, 2022 On 3/21/2022 at 6:27 PM, Luke said: @MSI2017 ? So, the subtitles themselves have appeared out of nowhere on some media files but the settings are gone. OpenSubtitles is installed and configured correctly. Latest emby server version. Will check logs later today
Luke 42186 Posted March 24, 2022 Posted March 24, 2022 Are you using the web interface to configure the settings?
MSI2017 48 Posted March 24, 2022 Author Posted March 24, 2022 (edited) 11 minutes ago, Luke said: Are you using the web interface to configure the settings? Normally I would but at the moment there is nothing to configure apart from OpenSubtitles login credentials Edited March 24, 2022 by MSI2017
