Romek123 42 Posted March 18, 2022 Posted March 18, 2022 I love the Emby Client - it looks good and its kinda handy, but the top and sidebars always visible is a moodbreaker. bars like this are tools, not design elements. they should only show up when i move per remote control to top or to side. This client would look rellay good when bars could be hidden. So my suggestion is: Please give us an option in client to hide the bars - to make them only visible when move top or right out of screen P.S. maybe this is possible already - i looked for it but could not find
MBSki 1115 Posted March 18, 2022 Posted March 18, 2022 49 minutes ago, Romek123 said: I love the Emby Client - it looks good and its kinda handy, but the top and sidebars always visible is a moodbreaker. I know the top bar is always there, but the sidebar isn't. What client are you using? The TV clients don't have any sidebar and on mobile clients the sidebar only shows up when you click the sidebar option in the top left.
Romek123 42 Posted March 18, 2022 Author Posted March 18, 2022 Could not answer earlier i was at work. Did not know there are difference in clients. I use the client on Nvidia shield pro - so i guess android? and i love the side bad - its very usefull - but i just don't wanna see it all the time when not using it
seanbuff 1356 Posted March 18, 2022 Posted March 18, 2022 Hmm what version of the Android TV app are you using on your Shield, because there has definitely been no side bar for many years. 1
seanbuff 1356 Posted March 18, 2022 Posted March 18, 2022 Can you show us a photo/screenshot of what you mean?
Romek123 42 Posted March 18, 2022 Author Posted March 18, 2022 ok i don't know how i could make a screenshot on my nvidia shield so i googled for one - this symbols on the right side for favorites, filter etc.
Luke 42246 Posted March 18, 2022 Posted March 18, 2022 How would you get to those things, or would you prefer them up top?
Romek123 42 Posted March 19, 2022 Author Posted March 19, 2022 (edited) hi luke - i would love to have them same as it is now. it just should be hidden and appear when move the cursor to the rightout of screen. same as i would move to this icons anyway. i googled for "hide menubar mouseover" and found this video in attachements. An effect like this would be nice for the client. watch[1] Edited March 19, 2022 by Romek123
seanbuff 1356 Posted March 19, 2022 Posted March 19, 2022 2 hours ago, Romek123 said: it just should be hidden and appear when move the cursor to the rightout of screen. How would anyone know they were there if they were hidden by default? 1 1
Romek123 42 Posted March 19, 2022 Author Posted March 19, 2022 (edited) Quote if they were hidden by default? It could be an option in cofiguration. Like: Bars always shown or fade out unused bars "always shown" should be the default configuration from the start Edited March 19, 2022 by Romek123
ebr 16338 Posted March 19, 2022 Posted March 19, 2022 2 hours ago, seanbuff said: How would anyone know they were there if they were hidden by default? This would be my biggest issue. It is a small tool bar that isn't taking up any space. The posters wouldn't move further to the right because then you wouldn't have room for the count at the bottom. In landscape layouts, vertical space is at a premium while horizontal space is a bit more available. 2
