Misinthe 46 Posted March 17, 2022 Posted March 17, 2022 Hello everyone, I am having a weird issue, it just started a couple of days ago, and it only happens when my baby is watching his one TV show, I'm not sure what's going on. We'll be watching it, and all of the sudden it will buffer for a second, then keep playing, then a couple of seconds later it jumps to the next episode. This has been working fine for years, it's his favorite TV show, I thought maybe the files got corrupted so I downloaded them again and it is still happening, I don't know what's going on. In the Logs, there's only one error that I can see, I don't know what it means. 2022-03-16 17:28:58.369 Error LibraryMonitor: Error in Directory watcher for: \\10.10.0.4\Server Media\TV Shows *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\msanchez\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.20348 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/msanchez/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\msanchez\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\msanchez\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Source: TargetSite: No Stack Trace Available 2022-03-16 17:28:58.369 Error LibraryMonitor: Error in Directory watcher for: \\10.10.0.4\Server Media\Cartoons *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\msanchez\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.20348 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/msanchez/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\msanchez\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\msanchez\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Source: TargetSite: No Stack Trace Available 2022-03-16 17:28:58.369 Info LibraryMonitor: Stopping directory watching for path \\10.10.0.4\Server Media\TV Shows 2022-03-16 17:28:58.369 Info LibraryMonitor: Stopping directory watching for path \\10.10.0.4\Server Media\Cartoons
Happy2Play 9801 Posted March 17, 2022 Posted March 17, 2022 Devs will probably need to see the full server log, but to me those snippets suggest the media paths are disconnecting.
Misinthe 46 Posted March 17, 2022 Author Posted March 17, 2022 54 minutes ago, Happy2Play said: Devs will probably need to see the full server log, but to me those snippets suggest the media paths are disconnecting. I figured, I just didn't want to upload, since it has my Public IP and everything, if someone can reach out I can PM them the Logs!
Happy2Play 9801 Posted March 17, 2022 Posted March 17, 2022 3 minutes ago, Misinthe said: I figured, I just didn't want to upload, since it has my Public IP and everything, if someone can reach out I can PM them the Logs! You can pm to me and I can add devs to the conversation.
Solution Misinthe 46 Posted March 18, 2022 Author Solution Posted March 18, 2022 On 16/03/2022 at 22:04, Happy2Play said: You can pm to me and I can add devs to the conversation. On 17/03/2022 at 11:15, Luke said: Did you find anything? Sorry I took so long to reply, I have been doing tests at nights after work, so it seems it was the NIC on my NAS, my Emby Server runs on a VM and reads from my TrueNAS box where all the media is stored, it seems the NIC couldn't handle the data transfer after I added 32TB more of storage. I replaced the NIC for a better one on my NAS and I haven't had issues yet. 1
