Luke 42255 Posted May 16, 2024 Posted May 16, 2024 Hi, how would you overlay the dv profile? That info can be verbose, no?
supermood 71 Posted May 16, 2024 Posted May 16, 2024 that's true. bad example. but dtsx atmos hdr10+ would be also new? Bitrate? anyway. tags. which is one is not so important you choose later
supermood 71 Posted May 16, 2024 Posted May 16, 2024 what kind of data is the plug in using to determine which overlay icon to show? not the tags I guess? then adding some more icons would be easy also not the emby ffmpeg data because yesterday I was told it cannot do dolby vision but the overlay is there thanks!
Luke 42255 Posted May 16, 2024 Posted May 16, 2024 2 hours ago, supermood said: what kind of data is the plug in using to determine which overlay icon to show? not the tags I guess? then adding some more icons would be easy also not the emby ffmpeg data because yesterday I was told it cannot do dolby vision but the overlay is there thanks! the emby ffmpeg build can detect dolby vision.
Luke 42255 Posted May 16, 2024 Posted May 16, 2024 Quote what kind of data is the plug in using to determine which overlay icon to show? All of the data that you see in the Media Info section at the bottom of the video detail screen.
supermood 71 Posted May 16, 2024 Posted May 16, 2024 17 minutes ago, Luke said: the emby ffmpeg build can detect dolby vision. I meant atmos and dtsx... that was my reason for the addon
supermood 71 Posted May 16, 2024 Posted May 16, 2024 18 minutes ago, Luke said: All of the data that you see in the Media Info section at the bottom of the video detail screen. I mean from where or better how is emby getting the data. now I have thanks to the addon finally all info, in tags, maybe I can use that info for more overlays like dts x..
Luke 42255 Posted May 19, 2024 Posted May 19, 2024 On 5/16/2024 at 7:09 PM, supermood said: I mean from where or better how is emby getting the data. now I have thanks to the addon finally all info, in tags, maybe I can use that info for more overlays like dts x.. ffprobe, so that means the ffmpeg build.
supermood 71 Posted May 19, 2024 Posted May 19, 2024 12 minutes ago, Luke said: ffprobe, so that means the ffmpeg build. and with these we are not having atmos and dts x icons / overlays if wanted? I thought someone recently said it can detect these? or someone adds the code to use the tags from the other media info addon to generate it... happy Sunday
Luke 42255 Posted May 20, 2024 Posted May 20, 2024 Hi, we will have atmos and dtsx detection in future updates. Thanks. 1
