Skyfay 19 Posted March 15, 2022 Posted March 15, 2022 Since the new ios, some things are always automatically outlined in the Emby app. This is also the case in the settings, for example, I forgot that in my video. RPReplay_Final1647343369.MP4
ClemHarvey 0 Posted March 16, 2022 Posted March 16, 2022 New to Emby and same issue here. I can connect to my server manually but i can't connect using Emby Connect. However, when connecting manually i use port 443 but on my server dashboard my remote access is using port 8096. Guess it's a common server issue with the new ios mentioned here.
Luke 42242 Posted March 18, 2022 Posted March 18, 2022 On 3/16/2022 at 9:55 AM, ClemHarvey said: New to Emby and same issue here. I can connect to my server manually but i can't connect using Emby Connect. However, when connecting manually i use port 443 but on my server dashboard my remote access is using port 8096. Guess it's a common server issue with the new ios mentioned here. Hi, it sounds like you need to configure your emby server network settings so that the remote address displays the correct port. Once you do that, then emby connect will use the port you want
Skyfay 19 Posted March 29, 2022 Author Posted March 29, 2022 2 minutes ago, Luke said: @ClemHarvey has this helped? What about the problem in the video above?
Luke 42242 Posted March 30, 2022 Posted March 30, 2022 Do you by chance have a bluetooth mouse connected?
Skyfay 19 Posted March 30, 2022 Author Posted March 30, 2022 2 hours ago, Luke said: Do you by chance have a bluetooth mouse connected? No, the problem occurs when nothing is connected at all, not even Airpods.
Luke 42242 Posted March 31, 2022 Posted March 31, 2022 On 3/30/2022 at 1:56 AM, Skyfay said: No, the problem occurs when nothing is connected at all, not even Airpods. OK we'll take a look at it. Thanks. 1
