negativzeroe 80 Posted March 13, 2022 Posted March 13, 2022 Listening to audio books at 2x speed, but if I rewind because someone talks to me or something, then it goes back to normal speed and it will not let me change back. Toward the end of the log. log.txt
Luke 42186 Posted March 14, 2022 Posted March 14, 2022 Hi there, what exactly do you mean by "will not let you change back" ?
negativzeroe 80 Posted March 14, 2022 Author Posted March 14, 2022 It just will not. I try to change the speed like right here in the screenshot but once I hit rewind, even if I'm already on 2x speed, it just stays locked to normal. I cannot change it back until I stop then resume, or sometimes I have to swipe away from recent before it will let me.
Happy2Play 9801 Posted March 14, 2022 Posted March 14, 2022 What client are you using? Does the same happen in the Web Client?
negativzeroe 80 Posted March 15, 2022 Author Posted March 15, 2022 22 minutes ago, Happy2Play said: What client are you using? Does the same happen in the Web Client? Android. And I just did a quick test and it does not seem to on mobile web.
negativzeroe 80 Posted March 18, 2022 Author Posted March 18, 2022 Do I need to pull more logs or does what I've provided help identify the issue?
Happy2Play 9801 Posted March 18, 2022 Posted March 18, 2022 On 3/14/2022 at 5:03 PM, negativzeroe said: Android. And I just did a quick test and it does not seem to on mobile web. Since it is a specific client issue I would think that dev would have to take a look. @ebr
Luke 42186 Posted March 19, 2022 Posted March 19, 2022 When you get 3.2.43, please let me know how that compares. Thanks.
negativzeroe 80 Posted March 19, 2022 Author Posted March 19, 2022 2 hours ago, Luke said: When you get 3.2.43, please let me know how that compares. Thanks. Right on. Do you still use Dropbox? I don't mind testing with apk.
Luke 42186 Posted March 19, 2022 Posted March 19, 2022 It's on both our website and live in the store.
negativzeroe 80 Posted March 19, 2022 Author Posted March 19, 2022 Oh I have had it for two days lol. Seems to work so far, I will post back if it happens again.
