petertn 0 Posted March 13, 2022 Posted March 13, 2022 Using EMBY on my synology. I have created 2 directories, one for music and one for movies. I have added each as its own library, but nothing shows up under the movie directory. I can run the movies straight from the NAS, but they do not exist in Emby. I have checked permissions, these are the same for both the Music and Movie folders. I have even removed and recreated the folders and library about 4 times, but it is still the same. Anyone any thoughts please
Luke 42243 Posted March 13, 2022 Posted March 13, 2022 Hi there, did you complete the library scan after setting up the emby library?
petertn 0 Posted March 13, 2022 Author Posted March 13, 2022 Absolutely.. but every time I initiate a library scan on the Movies folder.. it scans the Music folder .. it will not under any circumstances scan the movies folder. I have removed and re-added it at least 4 times.. and each time it is the same.. it will not see the contents of this folder.
Happy2Play 9812 Posted March 13, 2022 Posted March 13, 2022 Can you provide a server log and the paths you used when you created these libraries.
Luke 42243 Posted March 14, 2022 Posted March 14, 2022 @petertn ? You can learn how to locate the server log file here: Thanks.
Carlo 4561 Posted March 14, 2022 Posted March 14, 2022 @petertn Did you have a chance to try this again to get some fresh logs to upload so we can take a look? Or did you figure out the issue or your own?
Luke 42243 Posted March 14, 2022 Posted March 14, 2022 @petertn what library path did you add to your movies library? What library path did you add to your music library? All I see in your server log is: /volume1/Emby You can't use the same folder for both libraries. Try pointing music to: /volume1/Emby/Music and movies to: /volume1/Emby/Movies
petertn 0 Posted March 21, 2022 Author Posted March 21, 2022 (edited) Luke... sorry for the delay getting back... been really sick deleted my previous message.. didnt quite understand you. but.. yes.. somehow, I made EMBY .. the music folder and then EMBY and put Movies in it.. you were right. thank you.. all fixed.. really appreciated. kind regards Edited March 21, 2022 by petertn
Luke 42243 Posted March 21, 2022 Posted March 21, 2022 6 hours ago, petertn said: Luke... sorry for the delay getting back... been really sick deleted my previous message.. didnt quite understand you. but.. yes.. somehow, I made EMBY .. the music folder and then EMBY and put Movies in it.. you were right. thank you.. all fixed.. really appreciated. kind regards Thanks for the feedback.
