Spiff6418 0 Posted August 13, 2023 Posted August 13, 2023 Went though a few more use cases if that may help... With car on driveway, I went through "Album" path and "Latest Music" path. First I used CarPlay with Wifi (Phone in airplane mode) and a different cable than yesterday: - got a few misdirected messages about Premiere being required (although server has premiere "on"), - then a few messages about "problem loading this content", - then a few blank screen, it seems the content is loaded but does not display because when getting out of that display and right back in then the content shows (same behaviour with Album list or Song list for 1 Album) - more messages about "problem loading this content" Finally song plays after a couple of attempts to get it playing. Second I used Android Auto with Wifi Very similar behaviour wrt "problem loading this content". However the Android Auto seems more responsive, and one gets to the music playing with less frustration Third I used CarPlay with 4G (Wifi off) and the same different cable than yesterday (car still in driveway not mobile) Similar behaviour as above CarPlay with Wifi Finally I used CarPlay with 4G (Wifi off) and original cable (car still in driveway not mobile) Similar behaviour as above CarPlay with Wifi As a side Note my Library is as well huge as mentioned by some other people in this topic. Ultimately I got music playing but the car was immobile. It seems that owing to the time it takes to get content one gets frustrated and in a fast moving car handover between cell could be an issue (not sure)... Attached the logs recorded during the tests above. embyserver.txt
andige 2 Posted August 21, 2023 Posted August 21, 2023 As I have already written above: The problem seems to be that Emby needs to load the content of the whole folder or the whole playlist when using Carplay. If the folder/playlists contains hundreds of MB of data this can take a long time, depending on the quality of the mobile connection. I have checked this over the last couple of months over and over again within IOS (-> Settings -> Mobile Data -> Current Period): When using the Emby app alone (without Carplay), it starts to play immediately (and does not nearly download the same amount of data) while when using with Carplay it downloads the exact amount of data in the folder/playlist. This is not only annoying, but also a problem for many people who do not have a flatrate for mobile data. Together with the impossibility to use Downloads in Carplay this makes emby virtually unusable with Carplay. Emby Server Version 4.8.0.42 beta Emby App Version 2.2.10 IOS Version 16.6 Best regards, Andi
chart100 1 Posted August 21, 2023 Author Posted August 21, 2023 (edited) I gave up on using Emby for CarPlay. Dev appears somewhat uninterested in properly understanding and fixing the actual issue, which is quite frustrating as a paying user. Edited August 21, 2023 by chart100
issmail82 6 Posted August 29, 2023 Posted August 29, 2023 It's a shame, because it's the only thing keeping me using Plex. Please give some love to the CarPlay experience. If you need any assistance I will be happy to help.
issmail82 6 Posted October 1, 2023 Posted October 1, 2023 Hi, Any chance this will get some love from the Emby team ? Thanks
bravoland2 6 Posted October 5, 2023 Posted October 5, 2023 I have the same issue as others regarding Carplay and the random timeouts @Luke is there anything I can do to help test what is causing this or how to get more reliable results from carplay?
Luke 42241 Posted October 27, 2023 Posted October 27, 2023 Hi, we are looking into improving this. Thanks.
Tinky6418 1 Posted November 9, 2023 Posted November 9, 2023 On 27/10/2023 at 05:33, Luke said: Hi, we are looking into improving this. Thanks. thank you Sir, much appreciated 1
issmail82 6 Posted January 2, 2024 Posted January 2, 2024 Hi, Any ETA for this, as it's a dealbreaker (not working at all and no workaround as much as I know) ? Thanks !
Luke 42241 Posted January 5, 2024 Posted January 5, 2024 On 1/2/2024 at 10:05 AM, issmail82 said: Hi, Any ETA for this, as it's a dealbreaker (not working at all and no workaround as much as I know) ? Thanks ! Hi, we are working on improving it. Thanks.
Tormentor667 16 Posted February 6, 2024 Posted February 6, 2024 Just joining the thread - I have the same problem running at 2.2.17. Dear Luke, when can we expect a solution for that issue?
issmail82 6 Posted February 9, 2024 Posted February 9, 2024 Thanks Luke, but is there no timeline for when this can be fixed ? It’s kind of an emergency as there’s no workaround…
Guest Posted April 17, 2024 Posted April 17, 2024 I just moved over from plex where the carplay experience was amazing. I'm finding the Emby experience really bad in comparison. Pretty unseable. Is there any update on this? It appears that the original issue reported still exists. Im on the latest server, ios app.
issmail82 6 Posted April 21, 2024 Posted April 21, 2024 Yeah this is just embarrassing for a music player to not be able to play even one single track, and to let this linger for months...Can I please have my money back because seriously if I have known I wouldn't have made the switch 1
Guest Posted May 28, 2024 Posted May 28, 2024 Just checking if there has been any progress on this issue and what the plan might be going forward. On the latest 2.2.21 IOS app and carplay is still pretty unusable.
Luke 42241 Posted May 29, 2024 Posted May 29, 2024 16 hours ago, dpslabber said: Just checking if there has been any progress on this issue and what the plan might be going forward. On the latest 2.2.21 IOS app and carplay is still pretty unusable. HI, we are working on improving it. Thanks for the feedback.
Tormentor667 16 Posted May 30, 2024 Posted May 30, 2024 Dear Luke, the issue is now over two years old and the only answer that we get continuously is „We are working on it“. I mean, okay, I am working on my pension since 18 years and I have to work another 27 years before I can get it. It’s a long time but it’s at least a proper information regarding how long it will take. Any chance of getting a specific information when we can expect a working CarPlay app? 1
sjkiss 28 Posted October 15, 2024 Posted October 15, 2024 On 8/21/2023 at 4:04 AM, chart100 said: I gave up on using Emby for CarPlay. Dev appears somewhat uninterested in properly understanding and fixing the actual issue, which is quite frustrating as a paying user. Very disappointing.
sjkiss 28 Posted October 15, 2024 Posted October 15, 2024 I posted about my problem over here, but it basically is the same problem expressed here. If Plex works well with carplay I am out of here and I feel bad about that because I *love* the community here. It is super helpful and responsive. But this is pretty much the whole reason I use Emby.
sjkiss 28 Posted October 18, 2024 Posted October 18, 2024 Hi there, just an update. I feel really bad about this, because overall Emby has been phenomenal. I came here from Plex because the Emby DLNA server piped playlists that I created in the web UI to my DLNA devices. That was why I came here. But the carplay thing is just a disaster. It doesn't work at all. I have been testing out Plex again and, wow, it is *phenomenal*. Super quick, super slick, no problems. I don't have the bandwidth to fuck around with technology that doesn't help me so I'll be leaving Emby Premiere back to Plex. If you guys ever get back to getting Carplay working, feel free to let me know and I'll try to come back. In the meantime, thanks and get on that carplay. It's a basic use case.
DonMacaroni 55 Posted January 3, 2025 Posted January 3, 2025 I am afraid not, still has same problem, still does not support downloaded files. Unfortunately, CarPlay has been a big letdown as it is basically unusable, if your library is bigger then couple hundred tracks.
