softworkz 5133 Posted March 10, 2022 Posted March 10, 2022 OK. What do you get from this URL? http://localhost:8096/web/index.html#!/configurationpage?name=FfmpegOptions
agottschling 2 Posted March 10, 2022 Author Posted March 10, 2022 1 minute ago, softworkz said: OK. What do you get from this URL? http://localhost:8096/web/index.html#!/configurationpage?name=FfmpegOptions It takes me to the same place as Dashboard > Advanced Transcoding > FFmpeg Options. All selections appear to be the same
softworkz 5133 Posted March 10, 2022 Posted March 10, 2022 I don't understand. You said you don't see the FFmpeg Options tab?
agottschling 2 Posted March 10, 2022 Author Posted March 10, 2022 Just now, softworkz said: I don't understand. You said you don't see the FFmpeg Options tab? I apologize, I must've poorly explained myself. I can find the ffmpeg options, but I can't find the selection to disable the iHD driver so that it falls back to the i965 driver. The other selections in your screenshot appear just fine.
agottschling 2 Posted March 10, 2022 Author Posted March 10, 2022 Unless this is what I'm supposed to use?
softworkz 5133 Posted March 10, 2022 Posted March 10, 2022 Yes, this is what you're supposed to use... ::-)
softworkz 5133 Posted March 10, 2022 Posted March 10, 2022 Tick the checkbox and choose "i965 - Intel VA Driver" Then restart the server
agottschling 2 Posted March 10, 2022 Author Posted March 10, 2022 Just now, softworkz said: Tick the checkbox and choose "i965 - Intel VA Driver" Then restart the server Ok. I'll test it out and report back
agottschling 2 Posted March 10, 2022 Author Posted March 10, 2022 1 minute ago, softworkz said: I forgot: you need to click SAVE. I assumed that was implied. As for the available decoders, changing to the old driver didn't remove the HW HEVC decoder
softworkz 5133 Posted March 10, 2022 Posted March 10, 2022 No, it wont't remove it. I'm rather curious whether something would be working. Just move put QuickSync to the top, check HEVC, and the try to play back one H.264 and one H.265/HEVC video and post the logs. That would be great, thanks.
softworkz 5133 Posted March 10, 2022 Posted March 10, 2022 (edited) I already have a fix for the beta to remove the QuickSync codecs, but I don't want to take away something that might be working. (HEVC very unlikely, H264 rather unlikely...) Edited March 11, 2022 by softworkz
softworkz 5133 Posted March 12, 2022 Posted March 12, 2022 On 3/10/2022 at 2:46 PM, softworkz said: No, it wont't remove it. I'm rather curious whether something would be working. Just move put QuickSync to the top, check HEVC, and the try to play back one H.264 and one H.265/HEVC video and post the logs. That would be great, thanks. @agottschling - Have you had a chance to try?
agottschling 2 Posted March 12, 2022 Author Posted March 12, 2022 1 hour ago, softworkz said: @agottschling - Have you had a chance to try? Apologies for the delay. Here's the logs for a HEVC transcode and a h.264 transcode ffmpeg-transcode-459940ec-05b6-4551-8256-859f0336e455_1.txtffmpeg-transcode-2cd80aef-3570-4cd5-b907-b8f126beee4b_1.txtffmpeg-transcode-8215e40d-0ba1-4da3-b066-64fbd279bbcb_1.txt ffmpeg-transcode-01efa649-d4d6-4df5-ab58-67c6fad11400_1.txt And the main server log: embyserver.txt All of this was with the following settings in the transcoding dashboard: And the following in the Advanced Transcoding settings: Hope that helps, and if you need more info, please let me know.
softworkz 5133 Posted March 12, 2022 Posted March 12, 2022 Thanks, what I meant is testing QuickSync, through: On 3/10/2022 at 2:46 PM, softworkz said: Just move QuickSync to the top , check HEVC, and then try to play back one H.264 and one H.265/HEVC video and post the logs.
agottschling 2 Posted March 12, 2022 Author Posted March 12, 2022 4 minutes ago, softworkz said: Thanks, what I meant is testing QuickSync, through: Ah yes. I do see that now. Give me a few minutes and I'll redo the test.
agottschling 2 Posted March 12, 2022 Author Posted March 12, 2022 @softworkz Transcoding settings: HEVC -> H.264:ffmpeg-transcode-a0774ae6-5aed-4d2f-84ad-1ac901420363_1.txtffmpeg-transcode-a0774ae6-5aed-4d2f-84ad-1ac901420363_1.txt H.264 -> H.264:ffmpeg-transcode-a0774ae6-5aed-4d2f-84ad-1ac901420363_1.txt Main Server log for the whole time period: embyserver(2).txt Hope this helps. And let me know if you need other info.
softworkz 5133 Posted March 12, 2022 Posted March 12, 2022 Thanks. It seems that all three log files are the same. I'd need the one with h264 to h264, even though it seems it wasn't successful. Thanks
agottschling 2 Posted March 12, 2022 Author Posted March 12, 2022 ffmpeg-transcode-a8d06c66-8392-4121-a0b3-81816ec8d388_1.txtffmpeg-transcode-a0774ae6-5aed-4d2f-84ad-1ac901420363_1.txtffmpeg-transcode-82035e39-c68a-4438-a42e-7e340a3cbaa6_1.txt Here's all three. Don't know how I managed to attach the same file 3 times.
softworkz 5133 Posted March 12, 2022 Posted March 12, 2022 OK, thanks a lot for all your effort in trying these things! So here's the conclusion: It seems that in the recent versions of the Intel Media SDK (which provides those HWA codecs that ffmpeg calls QuickSync, even though it's actually Intel's name for the iGPU hw accel capability), it's not possible to enforce the use of the i965 driver instead of the iHD driver (like we tried). The iHD driver has always been the recommended driver for the MSDK, but I think in earlier versions it was possible to use it with the i965 driver. Also, there are artifacts in the MSDK (e.g. a constant like MFX_PLATFORM_SANDYBRIDGE) that indicate that earlier versions might have had support for that platform. It was an attempt to be sure that it's not only just HEVC which is non-working, but that QuickSync codecs aren't working at all on this platform (not even for H.264), so we can safely disable QSV functionality for all platforms before Broadwell, which is the earliest supported CPU gen for MSDK. This change will be included in the next beta version. When no QuickSync HEVC codecs will be detected, then they won't be erroneously chosen anymore, which will make sure that transcoding will be working again with default settings. Thanks again for your help in that matter, softworkz
agottschling 2 Posted March 13, 2022 Author Posted March 13, 2022 9 hours ago, softworkz said: OK, thanks a lot for all your effort in trying these things! So here's the conclusion: It seems that in the recent versions of the Intel Media SDK (which provides those HWA codecs that ffmpeg calls QuickSync, even though it's actually Intel's name for the iGPU hw accel capability), it's not possible to enforce the use of the i965 driver instead of the iHD driver (like we tried). The iHD driver has always been the recommended driver for the MSDK, but I think in earlier versions it was possible to use it with the i965 driver. Also, there are artifacts in the MSDK (e.g. a constant like MFX_PLATFORM_SANDYBRIDGE) that indicate that earlier versions might have had support for that platform. It was an attempt to be sure that it's not only just HEVC which is non-working, but that QuickSync codecs aren't working at all on this platform (not even for H.264), so we can safely disable QSV functionality for all platforms before Broadwell, which is the earliest supported CPU gen for MSDK. This change will be included in the next beta version. When no QuickSync HEVC codecs will be detected, then they won't be erroneously chosen anymore, which will make sure that transcoding will be working again with default settings. Thanks again for your help in that matter, softworkz Just to confirm though, VAAPI will still be available on these older Intel platforms right?
