Erik 124 Posted March 5, 2022 Posted March 5, 2022 Hello, Starting yesterday I started seeing double library selections in the user profile->access and also when they login the library shows twice. Any way to get rid of the double entry and fix this? Thanks!
Solution Luke 42186 Posted March 6, 2022 Solution Posted March 6, 2022 Hi, that's strange. I would try deleting the duplicate from Emby library setup.
Erik 124 Posted March 7, 2022 Author Posted March 7, 2022 Hi @Luke I deleted one of the duplicate libraries and it deleted them both of them. I had to re-setup the library and now its back to proper working status. Not sure what caused the duplicate, but in the users access screen if you selected one it would select both...very odd. Either way its all fixed now. Thanks.
Luke 42186 Posted March 7, 2022 Posted March 7, 2022 OK we'll try to chase down why that happened. Thanks for following up. 1
