Danimontes 11 Posted March 5, 2022 Posted March 5, 2022 Greetings!! I have emby installed in my Fire Stick. I have also attached an external drive to it. How can I configure Emby client to be able to download files to the drive? I can't see the option as like I do in my mobile Phone or other devices...
ebr 16337 Posted March 5, 2022 Posted March 5, 2022 Hi. For download functionality, you would need to install our standard Android app on the device but I'm curious how you attached an external drive to a Fire Stick...?
Danimontes 11 Posted March 5, 2022 Author Posted March 5, 2022 11 minutes ago, ebr said: Hi. For download functionality, you would need to install our standard Android app on the device but I'm curious how you attached an external drive to a Fire Stick...? Hi. Since FireOS 7 you can attach any drive (USB, external disk, etc...) using a HUB. Also, searching for Emby app in Appstore only gives me one result: the app I have already installed.
ebr 16337 Posted March 5, 2022 Posted March 5, 2022 18 minutes ago, Danimontes said: Also, searching for Emby app in Appstore only gives me one result: the app I have already installed. Yes, you would need to side load it. You can download from the link I provided. 1
rbjtech 5344 Posted March 5, 2022 Posted March 5, 2022 Yes USB is available on FireOS - on my FireTV (non Stick) the storage is mounted as /storage/usbotg I assume on the non ATV Emby Client version, this would be available like any Android Phone for example.
Danimontes 11 Posted March 5, 2022 Author Posted March 5, 2022 Yessss!!! It worked great!! Thank you all!!! Now I can see download option and choose USB storage. 1
