fivedays 1 Posted March 5, 2022 Posted March 5, 2022 I have a very large library with over 10,000 folders and files in it. When it was 9000+, it was running fine. When I add another 500+ files in it, it seems like it start running into problems.It cannot show more movies/shows and keep scanning the same folder. Right now, the number stopped at 9551. Here is the log file. Please let me know if you need more information. Thanks. embyserver.txt
visproduction 332 Posted March 5, 2022 Posted March 5, 2022 Just some guesses. When I look up some of the errors, I see people just shutting down and restarting helped. Obviously, try that first, if you haven't done it already. Every 3 seconds you get an error: 2022-03-05 00:19:29.029 Error App: sonos error sending soap request *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\fived\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.18363 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/fived/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 2 Data path: C:\Users\fived\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\fived\AppData\Roaming\Emby-Server\system System.InvalidOperationException: System.InvalidOperationException: There is an error in XML document (1, 235). ---> System.OverflowException: Value was either too large or too small for an unsigned byte. at System.Number.ThrowOverflowException(TypeCode type)... === Programdata/config/system.xml has these settings at the bottom: <CollapseVideoFolders>true</CollapseVideoFolders> <EnableOriginalTrackTitles>false</EnableOriginalTrackTitles> <VacuumDatabaseOnStartup>false</VacuumDatabaseOnStartup> <SimultaneousStreamLimit>0</SimultaneousStreamLimit> <DatabaseCacheSizeMB>512</DatabaseCacheSizeMB> <EnableSqLiteMmio>false</EnableSqLiteMmio> <NextUpUpgraded>true</NextUpUpgraded> <ChannelOptionsUpgraded>true</ChannelOptionsUpgraded> <OptimizeDbOnShutdown>false</OptimizeDbOnShutdown> <DatabaseAnalysisLimit>400</DatabaseAnalysisLimit> === I would guess DatabaseCacheSizeMB and DatabaseAnalysistLimit values might have something to do with your issue. I am looking at this code for the first time, so it's quite likely I don't know the real reason. Back up everything before tweaking anything.
Luke 42186 Posted March 5, 2022 Posted March 5, 2022 Please try removing the third party plugins that you've installed, then restart the server and see if the issue persists. Thanks .
fivedays 1 Posted March 6, 2022 Author Posted March 6, 2022 3 hours ago, Luke said: Please try removing the third party plugins that you've installed, then restart the server and see if the issue persists. Thanks . Yep. That seems the case. When I removed the sonos third party plug-in and restarted the server, I found that one of the scanning folder is missing from this library. Not sure why it is missing, I dont recall removing any. Anyways, It seems like the server is working fine without the sonos plug-in. All the files have been scanned and discovered. Thanks.
