lmitchel 0 Posted March 5, 2022 Posted March 5, 2022 Recently Emby has not been able to identify TV shows. I tried refreshing metadata etc. I finally uninstalled TheTVDBD and went to reinstall it but the plugin catalog was empty. After some troubleshooting including disabling ipv6 I read the log files. I found the following error and have attached the complete log file.: *** Error Report *** Version: 4.6.5.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Linux version 4.18.0-348.12.2.el8_5.x86_64 (mockbuild@dal1-prod-builder001.bld.equ.rockylinux.org) (gcc version 8.5.0 20210514 (Red Hat 8.5.0-3) (GCC) Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. at System.Net.Security.SslStream.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) I was able to curl the file with no problems from a command prompt. What can I do to resolve the issue? EmbyPluginCatalogError.txt
Happy2Play 9813 Posted March 5, 2022 Posted March 5, 2022 To me your system has a certificate issue as all remote connections are having issues. (Emby blog/News, GitHub, mb3admin) The remote certificate is invalid according to the validation procedure. But you are on an old install 4.6.5.0 and 4.6.6.0+ resolved Linux distro issues. Fix outgoing SSL errors on some Linux distros Is there an issue you have not updated?
lmitchel 0 Posted March 5, 2022 Author Posted March 5, 2022 I admit I was lazy and didn't look on the website for an update and relied on the checkbox as shown. I'll bet it couldn't report it was out of date due to the same problem.... Perhaps if the update check fails it should report other than "up to date". I have updated it to 4.6.7.0 and it now works again. Thank you for the quick response and diagnosis.
Luke 42246 Posted March 5, 2022 Posted March 5, 2022 7 hours ago, lmitchel said: I admit I was lazy and didn't look on the website for an update and relied on the checkbox as shown. I'll bet it couldn't report it was out of date due to the same problem.... Perhaps if the update check fails it should report other than "up to date". I have updated it to 4.6.7.0 and it now works again. Thank you for the quick response and diagnosis. Yes that is exactly right about why it couldn't report. Thanks for the feedback.
Happy2Play 9813 Posted March 5, 2022 Posted March 5, 2022 11 hours ago, lmitchel said: Perhaps if the update check fails it should report other than "up to date". Are/where there not red failed attempts in Alerts? old example
