Svennie 4 Posted March 10, 2022 Author Posted March 10, 2022 On 3/9/2022 at 12:58 AM, Svennie said: Yes, as you specified. I'll watch it for a few days. The problem is still there. Here's what happened: The same live stream was started twice and ended twice. However, the stream continues in the background. I suspect the streams in the background that have been started twice remain open. This is the broadcaster "RTL". The log file can be called up via Dropbox because it is too big for the forum. https://www.dropbox.com/s/onrbv6virkcs45q/embyserver(7).txt?dl=0
Guest Posted March 10, 2022 Posted March 10, 2022 since last beta update i have issues with live tv. the streams doesn't end anymore. after watching 2-3 streams there is no free tuner anymore.
Svennie 4 Posted March 10, 2022 Author Posted March 10, 2022 (edited) 13 minutes ago, Dax99 said: since last beta update i have issues with live tv. the streams doesn't end anymore. after watching 2-3 streams there is no free tuner anymore. Hast du eine Box mit FBC Tuner? Enden alle Streams nicht mehr oder eventuell nur die, die doppelt gestartet wurden? Kannst du die Log für Luke eventuell auch mal hochladen? Edited March 10, 2022 by Svennie
Guest Posted March 11, 2022 Posted March 11, 2022 Nein kein FBC Tuner. Ist ne Dreambox One mit 2 Tuner. Log kann ich später machen.
