Abobader 3485 Posted August 17, 2024 Author Posted August 17, 2024 Good day, We return the modifications temp after the update, I will replace them soon with more modern and customization than before. Templates I need to delay them more before I start modifying them back again. Speed will improve for sure later on, as we really update the server-php-mysql-forum all at once, so sure something need to be optimize and we are working on it. Thanks all. My best 4
Q-Droid 1011 Posted August 17, 2024 Posted August 17, 2024 On 8/15/2024 at 8:56 PM, softworkz said: An (at least temporary) alternative for getting a list of all recent changes in all forums is menu: Activity >> All Activity (for those who don't know) This view is loading as fast as usual. I had used activity streams before and even had saved a couple I customized. But then the single click "Fluid" mode on the home page was simple enough that I forgot about the others. Now the "Temp Fluid" stream I've created as a workaround is growing on me and I might even stick with it. 2
Abobader 3485 Posted August 29, 2024 Author Posted August 29, 2024 On 8/17/2024 at 4:26 AM, TMCsw said: minor reputation is missing... Done. 1 1
GrimReaper 4893 Posted August 29, 2024 Posted August 29, 2024 6 minutes ago, Abobader said: Done. Still missing in Mobile view. 1
Abobader 3485 Posted August 29, 2024 Author Posted August 29, 2024 ah, mobile horror I will see how to fix this. 1
Abobader 3485 Posted August 31, 2024 Author Posted August 31, 2024 Good day, As we did cleanup and remove the edit form our templates, within these tasks the "Member Title" table-column removed from the db. You can easily add back by edit your profile if you wanted back. What is member title? As I add it back just to show you, it the title under your user name, in my case it is: Super-Tester. My best 1
Abobader 3485 Posted September 3, 2024 Author Posted September 3, 2024 On 8/29/2024 at 10:03 AM, GrimReaper said: Still missing in Mobile view. Done. 1
darkassassin07 674 Posted September 23, 2024 Posted September 23, 2024 On 2/27/2024 at 7:34 PM, Abobader said: @darkassassin07 Yes, the problem here what we used as a modify, do not work well with latest build we did some months ago. Please give me time to solve this, and indeed it sucks as it is now, sorry buddy. Hey @Abobader, you still looking into this problem? I still quite regularly run into unreadable content on this forum.... 1 3
Abobader 3485 Posted September 24, 2024 Author Posted September 24, 2024 Hi @darkassassin07 The problem with above example is: When a user chose background/foreground color, that will happens. My best
CBers 7554 Posted September 24, 2024 Posted September 24, 2024 1 hour ago, Abobader said: When a user chose background/foreground color, that will happens Can that option be removed? 1 2
Neminem 1619 Posted September 24, 2024 Posted September 24, 2024 Yes please, if ppl paste from a translator or word etc please make sure it inserted as plain text. Plain text inset option is almost always ignored. 1 1
darkassassin07 674 Posted September 24, 2024 Posted September 24, 2024 I don't think users are deliberately choosing background colours. I think they are being automatically set when copy-pasting text. Background colours should be stripped from posts imo. 1 2
Abobader 3485 Posted September 24, 2024 Author Posted September 24, 2024 Good day, The problem with the forum software we used, it use old editor, thing will change with the next major update one. I will high consider your request regarding the editor matters. Thanks. My best 3
Abobader 3485 Posted September 24, 2024 Author Posted September 24, 2024 Font color & source options is now remove from the editor toolbars .
GrimReaper 4893 Posted September 24, 2024 Posted September 24, 2024 Well, you can never make everyone happy - I, for one, am quite unhappy with font color removal and slightly unhappy with source removal. 2
Abobader 3485 Posted September 24, 2024 Author Posted September 24, 2024 39 minutes ago, GrimReaper said: Well, you can never make everyone happy - I, for one, am quite unhappy with font color removal and slightly unhappy with source removal. We sure do not want that, I restore it back. I will think on another way that not effected this. Our goal to make everything work as it should, dark themes are important, so I need time to fix this, thanks all. 1 3
Abobader 3485 Posted October 1, 2024 Author Posted October 1, 2024 Good day, We at the moment doing some cleaning for some attachments, like logs, zip/rar files, we need to reduce the huge amount for the storage space been taking by the these. Thanks. My best 2
Gilgamesh_48 1243 Posted October 1, 2024 Posted October 1, 2024 5 hours ago, Abobader said: Good day, We at the moment doing some cleaning for some attachments, like logs, zip/rar files, we need to reduce the huge amount for the storage space been taking by the these. Thanks. My best Maybe the log files should be automagically deleted after a month or two. By that time any real usefulness from log attachments would be effectively nil as, most of the time, the server would have jumped a version or three.
softworkz 5133 Posted October 1, 2024 Posted October 1, 2024 17 minutes ago, Gilgamesh_48 said: Maybe the log files should be automagically deleted after a month or two. It's those 0.1% of cases where it's extremely useful to have older log files for comparison. Something like 3 years would be fine, though IMO.
softworkz 5133 Posted October 1, 2024 Posted October 1, 2024 On 9/24/2024 at 6:02 PM, Abobader said: I will think on another way that not effected this. Our goal to make everything work as it should, dark themes are important, so I need time to fix this, thanks all. When wil we have the new editor version? Then I can look into creating an editor-plugin for cleaning up colors. Since I've already created one (for the ## links), it should go quickly.
Gilgamesh_48 1243 Posted October 1, 2024 Posted October 1, 2024 5 minutes ago, softworkz said: It's those 0.1% of cases where it's extremely useful to have older log files for comparison. Something like 3 years would be fine, though IMO. Then make it 3 years if that is the best that can be done. However, if it must be longer than a few months there is little need to go back as far as 3 years. I think a max duration of 1.5 years would make a good compromise but, it seems to me that anything over one year is vast overkill. But I neither run this site or have any direct impact here. I just wish to try and make semi-intelligent suggestions.
softworkz 5133 Posted October 1, 2024 Posted October 1, 2024 37 minutes ago, Gilgamesh_48 said: Then make it 3 years if that is the best that can be done. However, if it must be longer than a few months there is little need to go back as far as 3 years. I think a max duration of 1.5 years would make a good compromise but, it seems to me that anything over one year is vast overkill. "semi-intelligent" is a good description for these two sentences, LOL
Gilgamesh_48 1243 Posted October 1, 2024 Posted October 1, 2024 Just now, softworkz said: "semi-intelligent" is a good description for these two sentences, LOL Why do you have to be insulting? Your post contributed NOTHING.
softworkz 5133 Posted October 1, 2024 Posted October 1, 2024 9 minutes ago, Gilgamesh_48 said: Why do you have to be insulting? Your post contributed NOTHING. Sorry, I didn't mean to be insulting at all. I just repeated your own phrase. 12 minutes ago, softworkz said: Then make it 3 years if that is the best that can be done. However, if it must be longer than a few months there is little need to go back as far as 3 years. I failed to see any logic in these sentences, that's why I just meant to confirm your own assessment of your suggestion, that' s all. Not meant to be unfriendly. 13 minutes ago, Gilgamesh_48 said: Your post contributed NOTHING I meant to say that - from past experience - a minumum of 3 years retention is needed for development purposes. For example In case of regressions User says "it has worked before". Having older logs allows to check whether that's really true or whether it's been a different case Feature Implementation Often, long-standing issues are implemented after quite some time. For that, it's useful to be able to view the original logs that are showing the case it was actually about Late Fixes Not everything gets fixes in-time. Sometimes it's months later that we get to it etc. Every one in a while it happens that I'm looking at older log files and each time I'm glad that they are still there. 1
