rjmiller91 0 Posted March 2, 2022 Posted March 2, 2022 so yeah im in desperate need of help to set up my remote access for my emby server. if someone is willing to talk me through it i can talk on discord or through here.
lorac 119 Posted March 2, 2022 Posted March 2, 2022 settings>network>check enable automatic port forwarding if that does not fix it you will need to log into your router to manually forward the port.
Sammy 791 Posted March 2, 2022 Posted March 2, 2022 https://support.emby.media/support/solutions/articles/44002137137-remote-setup
Luke 42243 Posted March 2, 2022 Posted March 2, 2022 Hi there @rjmiller91 I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
