phunzie 42 Posted February 28, 2022 Posted February 28, 2022 (edited) for about a year now, probably since i updated to Kodi Matrix (and started using Add-on mode), i have been experiencing playback issues when first starting a movie/video file (mkv)....for the first 20-30 seconds of most files i would have brief 1-2 second periods of jerky playback/ stuttering, but then eventually the rest of the video would play fine it was annoying but i got somewhat used to it, but after updating to Emby 6.2.10, the jerkiness/stuttering seemed to get a little worse i had assumed it might be a hardware issue with my HTPC system, but now noticed the same mkvs played smoothly with players like VLC and MPC-HC i had been using Emby in Add-On mode, so then experimented with using Native mode, and was surprised to find that now the video files play smoothly from the very beginning, no more stuttering/jerkiness what could be the reason for this? Edited March 1, 2022 by phunzie
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 2 hours ago, phunzie said: i had assumed it might be a hardware issue with my HTPC system, but now noticed the same mkvs played smoothly with players like VLC and MPC-HC Did you play the same network stream via VLC?
phunzie 42 Posted February 28, 2022 Author Posted February 28, 2022 i pointed VLC directly to the file on my hdd, did not use an http address
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 23 minutes ago, phunzie said: i pointed VLC directly to the file on my hdd, did not use an http address Well you should to perform a proper test. Also you should use plugin's webservice as proxy. When you start a Kodi playback via addon mode, you will find in kodi.log the query address. Something like 127.0.0.1 bla. When Kodi is running, you can use this url in VLC as network stream address and you perform a complete test of the stream functionality from next-gen plugin. If this is fine, and that's what I'm expecting, then it's a Kodi issue. 1
phunzie 42 Posted February 28, 2022 Author Posted February 28, 2022 51 minutes ago, quickmic said: Also you should use plugin's webservice as proxy. how do i do this?
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 (edited) 37 minutes ago, phunzie said: how do i do this? Play a movie in Kodi via addon mode. (no debug mode required) Stop the movie. Close Kodi open the kodi.log Search for the URL which init's the stream (or upload the log file, an I tell you). When URL identified: Start Kodi Open VLC Drop the URL in VLC (open network stream) VLC should play the stream Edited February 28, 2022 by quickmic
phunzie 42 Posted February 28, 2022 Author Posted February 28, 2022 thanks, but i know how to find/play the stream, but i was asking how to “use plugin's webservice as proxy.”
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 (edited) You play regular content via Kodi in addon mode. This always uses the plugins webservice (proxy) cause the plugin in addon mode acts as proxy. Kodi always calls 127.0.0.1 bla url which is the plugin proxy. The Proxy redirects to the actual Emby server url. Here an example from kodi.log 2022-02-28 18:46:07.537 T:32455 INFO <general>: Loading skin file: DialogContextMenu.xml, load type: KEEP_IN_MEMORY 2022-02-28 18:46:08.761 T:32455 INFO <general>: VideoPlayer::OpenFile: http://127.0.0.1:57342/movies/f137a2dd21bbc1b99aa5c0f6bf02a805/embyvideo-2a38697ffc1b428b943aa1b6014e2263-9113-a114f27adeb425418fd202b4f3d9e0bb-a114f27adeb425418fd202b4f3d9e0bb-8900-5260-5260-movie-6471341-False-1-1-2-hevc-Lay_Bare__2012_.mkv 2022-02-28 18:46:08.761 T:35830 INFO <general>: Creating InputStream You can see, Kodi calls "http://127.0.0.1:57342/movies/f137a2dd21bbc1b99aa5c0f6bf02a805/embyvideo-2a38697ffc1b428b943aa1b6014e2263-9113-a114f27adeb425418fd202b4f3d9e0bb-a114f27adeb425418fd202b4f3d9e0bb-8900-5260-5260-movie-6471341-False-1-1-2-hevc-Lay_Bare__2012_.mkv" When the plugin is running, you can drop that same URL in VLC and it's piped through plugins webservice/proxy. If you test it like that, you can simulate what Kodi is actually doing. It calls a Network stream, the plugin redirects to actual Emby server url. In debug mode you can actually see the redirection URL as well, but DON'T drop a debug log here. The redirection URL will include your Emby server keys! Edited February 28, 2022 by quickmic 1
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 (edited) 33 minutes ago, quickmic said: You play regular content via Kodi in addon mode. This always uses the plugins webservice (proxy) cause the plugin in addon mode acts as proxy. Kodi always calls 127.0.0.1 bla url which is the plugin proxy. The Proxy redirects to the actual Emby server url. Here an example from kodi.log 2022-02-28 18:46:07.537 T:32455 INFO <general>: Loading skin file: DialogContextMenu.xml, load type: KEEP_IN_MEMORY 2022-02-28 18:46:08.761 T:32455 INFO <general>: VideoPlayer::OpenFile: http://127.0.0.1:57342/movies/f137a2dd21bbc1b99aa5c0f6bf02a805/embyvideo-2a38697ffc1b428b943aa1b6014e2263-9113-a114f27adeb425418fd202b4f3d9e0bb-a114f27adeb425418fd202b4f3d9e0bb-8900-5260-5260-movie-6471341-False-1-1-2-hevc-Lay_Bare__2012_.mkv 2022-02-28 18:46:08.761 T:35830 INFO <general>: Creating InputStream You can see, Kodi calls "http://127.0.0.1:57342/movies/f137a2dd21bbc1b99aa5c0f6bf02a805/embyvideo-2a38697ffc1b428b943aa1b6014e2263-9113-a114f27adeb425418fd202b4f3d9e0bb-a114f27adeb425418fd202b4f3d9e0bb-8900-5260-5260-movie-6471341-False-1-1-2-hevc-Lay_Bare__2012_.mkv" When the plugin is running, you can drop that same URL in VLC and it's piped through plugins webservice/proxy. If you test it like that, you can simulate what Kodi is actually doing. It calls a Network stream, the plugin redirects to actual Emby server url. In debug mode you can actually see the redirection URL as well, but DON'T drop a debug log here. The redirection URL will include your Emby server keys! btw, this works ONLY from the same device! 127.0.0.1 is only valid when VLC is running on the same device where Kodi/addon is running (localhost address). But you mentioned, you have a HTPC so shouldn't be a problem. Edited February 28, 2022 by quickmic
phunzie 42 Posted February 28, 2022 Author Posted February 28, 2022 ok, thanks for the explanation so i played the stream with VLC, and as you expected, it plays smoothly...so i guess it must be a Kodi issue as you suspected 1
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 1 minute ago, phunzie said: ok, thanks for the explanation so i played the stream with VLC, and as you expected, it plays smoothly...so i guess it must be a Kodi issue as you suspected This proves that Kodi has an issue. What you can try to fix it: Adjust Kodi network cache settings -> https://kodi.wiki/view/HOW-TO:Modify_the_video_cache Also try disable or enable http2 support (possible in plugin settings) 1
quickmic 1709 Posted February 28, 2022 Posted February 28, 2022 23 minutes ago, quickmic said: This proves that Kodi has an issue. What you can try to fix it: Adjust Kodi network cache settings -> https://kodi.wiki/view/HOW-TO:Modify_the_video_cache Also try disable or enable http2 support (possible in plugin settings) Try this: <advancedsettings> <cache> <buffermode>1</buffermode> <memorysize>0</memorysize> <readfactor>60</readfactor> </cache> </advancedsettings> That's the sledgehammer.
phunzie 42 Posted February 28, 2022 Author Posted February 28, 2022 i played around with adjusting the cache settings as described in your link to the Kodi Wiki and disabling HTPP2, but no improvement i did not try putting memorysize to 0, as i don't want to use my drives so much...i do have 8GB of RAM could be a coincidence, but another thing i've noticed since using Add-on mode for most of the past year, is that often times Kodi locks up when i try to exit, so i have to use Windows to force it closed i'm going to use Native mode for a while to see if these behaviors improve 1
