jsc1205 51 Posted February 28, 2022 Posted February 28, 2022 I have noticed that the title logo (when available) is replacing the standard text name of the movie on a couple of clients. Any idea when this will take affect on the Shield TV? Also, any upcoming new layout designs in the works?
Solution GrimReaper 4898 Posted February 28, 2022 Solution Posted February 28, 2022 It is already available in beta branch from 2.0.49: Quote 2.0.49 Increase poster size in grid Increase timeout on image loading Fall back to channel logo for programs with no image Add mkv as supported audio-only container Add logo as title option Fix down shortcut only works when play button focused Fix up shortcut doesn't work when OSD visible Show only relevant tabs in home videos library If you wanna sideload it:
jsc1205 51 Posted February 28, 2022 Author Posted February 28, 2022 Thanks for the quick reply and will check it out! 1
jsc1205 51 Posted February 28, 2022 Author Posted February 28, 2022 What is the best way to sideload it?
jsc1205 51 Posted February 28, 2022 Author Posted February 28, 2022 Disregard.....think I figured it out.
Luke 42245 Posted February 28, 2022 Posted February 28, 2022 14 hours ago, jsc1205 said: Disregard.....think I figured it out. Hi there, what was the solution?
