thunderclap 52 Posted February 24, 2022 Posted February 24, 2022 (edited) Correct me if I'm wrong, but I assume "Auto" for PQ settings should detect the best display and bitrate to stream, right? The reason I ask is because my dad was getting a black screen on several videos and it wasn't until I had him set the PQ manually it fixed the issue. How does Emby get this info from the TV? I'm happy it was a simple fix, but I'm trying to understand why it wasn't working like it was supposed to. I know he has a Roku Stick 3800x plugged into a Samsung TV, though the model TV I don't know. It was hard enough walking him through getting the Roku model number. Thanks. Edited February 24, 2022 by mbuhmann
Happy2Play 9811 Posted February 24, 2022 Posted February 24, 2022 Pretty much if a remote item will not direct play Auto will fallback to the clients hard coded bitrate around 1.5Mbps. It is best to just set a specific quality. Here is an example. Quote 20:20:08.340 Duration: 01:34:02.53, start: 0.000000, bitrate: 7352 kb/s 20:20:08.340 Stream #0:0[0x1](und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709, progressive), 1920x800 [SAR 1:1 DAR 12:5], 6705 kb/s, Level 41, 25 fps, 25 tbr, 12800 tbn (default) to 20:20:08.460 Stream #0:0: Video: h264, qsv(progressive), 426x176 [SAR 1:1 DAR 213:88], q=2-31, 151 kb/s, Level 30, 25 fps, 90k tbn 20:20:08.460 cpb: bitrate max/min/avg: 151598/0/151598 buffer size: 303196 vbv_delay: N/A
thunderclap 52 Posted February 24, 2022 Author Posted February 24, 2022 21 minutes ago, Happy2Play said: Pretty much if a remote item will not direct play Auto will fallback to the clients hard coded bitrate around 1.5Mbps. It is best to just set a specific quality. Here is an example. Is there a way for me as the admin of the server to set what I want the default to be, such as 720p 10 Mbps?
Happy2Play 9811 Posted February 24, 2022 Posted February 24, 2022 Just now, mbuhmann said: Is there a way for me as the admin of the server to set what I want the default to be, such as 720p 10 Mbps? Sorry there is no way to remote control these device settings. You would need to have the user set that quality on the device. Or you could have the user set the device to max value then you apply "Internet streaming bitrate limit (Mbps):" to the user.
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 So are you saying it’s the bitstream that’s the culprit for the black screen, or is it because of the resolution? I tried having him drop it to 1080p 60 Mbps but that didn’t work, and I know he can handle over 100 Mbps.
Happy2Play 9811 Posted February 25, 2022 Posted February 25, 2022 2 minutes ago, mbuhmann said: So are you saying it’s the bitstream that’s the culprit for the black screen, or is it because of the resolution? I tried having him drop it to 1080p 60 Mbps but that didn’t work, and I know he can handle over 100 Mbps. Would need corresponding logs but I really doubt high bitrate items will work across the internet. I have 100+Mbps but know my ISP throttles as I cannot download faster than 50Mbps. Are you sayings your upload speed is 100Mbps?
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 12 hours ago, mbuhmann said: So are you saying it’s the bitstream that’s the culprit for the black screen No, I think you are avoiding the real issue by setting the bitrate lower. The Roku app tests the connection and chooses an appropriate bitrate. It is fairly good at this and we don't have many problems with this app in this regard. My guess is there is something about this specific video or videos that the Roku player doesn't like so they need to be transcoded to play back properly. Are they Dolby Vision or something like that? Let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 15 hours ago, Happy2Play said: Pretty much if a remote item will not direct play Auto will fallback to the clients hard coded bitrate around 1.5Mbps This is not correct. We do not fall back to 1.5Mb/s if direct play fails.
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 1 hour ago, ebr said: No, I think you are avoiding the real issue by setting the bitrate lower. The Roku app tests the connection and chooses an appropriate bitrate. It is fairly good at this and we don't have many problems with this app in this regard. My guess is there is something about this specific video or videos that the Roku player doesn't like so they need to be transcoded to play back properly. Are they Dolby Vision or something like that? Let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! As requested here is a copy from the server log as it relates to my my father's Roku Stick 3800. Default yielded a black screen, and when I had him manually drop the PQ to 1080p 60 Mpbs it did the same thing. It finally worked when I had him change it to 720p 10 Mbps. The two videos I had him try were HDR 10 MKV's at approx. 15 Mbps. ffmpeg-transcode-5f6c68e9-f3b2-494a-a376-f83e6387316b_1.txt
Happy2Play 9811 Posted February 25, 2022 Posted February 25, 2022 @ebrWhy would it say HEVC is not supported on a Roku Streaming Stick? But this log shows 15Mbps HEVC converted to 30Mbps H264. So there could be a bandwidth issue and causing lower setting to work. VideoCodec=h264,mpeg2video &TranscodeReasons=VideoCodecNotSupported 16:41:22.982 Duration: 03:01:58.91, start: 0.000000, bitrate: 15464 kb/s 16:41:22.982 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x1608, SAR 1:1 DAR 160:67, Level 150, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc 16:41:22.984 Stream #0:0 (hevc) -> tonemap_vaapi (graph 0) 16:41:22.984 tonemap_vaapi (graph 0) -> Stream #0:0 (h264_vaapi) 16:41:22.984 Stream #0:1 -> #0:1 (aac (native) -> ac3 (native) 16:41:23.072 Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 3840x1608 [SAR 1:1 DAR 160:67], q=-1--1, 30928 kb/s, Level 51, 23.98 fps, 90k tbn, 23.98 tbc (default)
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 1 minute ago, Happy2Play said: @ebrWhy would it say HEVC is not supported on a Roku Streaming Stick? But this log shows 15Mbps HEVC converted to 30Mbps H264. So there could be a bandwidth issue and causing lower setting to work. VideoCodec=h264,mpeg2video &TranscodeReasons=VideoCodecNotSupported 16:41:22.982 Duration: 03:01:58.91, start: 0.000000, bitrate: 15464 kb/s 16:41:22.982 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x1608, SAR 1:1 DAR 160:67, Level 150, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc 16:41:22.984 Stream #0:0 (hevc) -> tonemap_vaapi (graph 0) 16:41:22.984 tonemap_vaapi (graph 0) -> Stream #0:0 (h264_vaapi) 16:41:22.984 Stream #0:1 -> #0:1 (aac (native) -> ac3 (native) 16:41:23.072 Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 3840x1608 [SAR 1:1 DAR 160:67], q=-1--1, 30928 kb/s, Level 51, 23.98 fps, 90k tbn, 23.98 tbc (default) The 3800 model of the Roku Sticks don't support 4k or HDR so it has to convert, which I knew. And as I mentioned in a previous post my dad has bandwidth of approx. 100 Mbps, and I have fiber which hits approx. 900 Mpbs so I don't think it's a bandwidth issue.
Happy2Play 9811 Posted February 25, 2022 Posted February 25, 2022 (edited) 5 minutes ago, mbuhmann said: The 3800 model of the Roku Sticks don't support 4k or HDR so it has to convert, which I knew. And as I mentioned in a previous post my dad has bandwidth of approx. 100 Mbps, and I have fiber which hits approx. 900 Mpbs so I don't think it's a bandwidth issue. But you say it works at 10Mbps, so that suggests a bandwidth issue or ISP throttling/traffic shaping. Also it is reporting it supports 4K. &MaxWidth=3840&MaxHeight=2160 Edited February 25, 2022 by Happy2Play
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 6 minutes ago, mbuhmann said: The 3800 model of the Roku Sticks don't support 4k or HDR 24 minutes ago, mbuhmann said: The two videos I had him try were HDR 10 MKV's Hi. There is your answer. The app needs to have a way to know that this is not supported and force the transcode. I thought we already had this so I'll have to look. 3 minutes ago, Happy2Play said: But you say it works at 10Mbps, so that suggests a bandwidth issue or ISP throttling/traffic shaping This isn't a bitrate problem. Reducing the bitrate is just forcing the transcode. 1
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 (edited) 2 minutes ago, ebr said: Hi. There is your answer. The app needs to have a way to know that this is not supported and force the transcode. I thought we already had this so I'll have to look. I am curious why it didn't work then when I had him drop it to 1080p 60 Mbps? That forced it to transcode, no? Edited February 25, 2022 by mbuhmann
Happy2Play 9811 Posted February 25, 2022 Posted February 25, 2022 (edited) 2 minutes ago, mbuhmann said: I am curious why it didn't work, then, when I had him drop it to 1080p 60 Mbps? That forced it to transcode, no? If that log was that setting, then no as it maintained 4K. Quote 16:41:23.072 Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 3840x1608 [SAR 1:1 DAR 160:67], q=-1--1, 30928 kb/s, Level 51, 23.98 fps, 90k tbn, 23.98 tbc (default) Edited February 25, 2022 by Happy2Play
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 1 minute ago, Happy2Play said: If that log was that setting, then no as it maintained 4K. That was the first time I had him try. Let me see if I can track down the 1080p log.
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 5 minutes ago, ebr said: This isn't a bitrate problem. Reducing the bitrate is just forcing the transcode. Well, wait a minute... now I see what Happy is talking about. The ffmpeg log above is from when the max bitrate was at 60. @mbuhmann are you saying this played with just a black screen?
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 So it is the resolution that is the problem, not the bitrate. Can you please play that item for a few seconds and then follow the instructions to send a log from the app? 1
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 Here is the log from when I had him drop the video to 1080p 60Mbps. ffmpeg-transcode-72377730-1953-4769-8101-25ae5f6e9913_1.txt
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 5 minutes ago, ebr said: So it is the resolution that is the problem, not the bitrate. Can you please play that item for a few seconds and then follow the instructions to send a log from the app? This will be a challenge. My dad is 80 and lives 5 hrs away. It will take time to try and walk him through this, and I'm at work right now so it might have to be a weekend project.
Happy2Play 9811 Posted February 25, 2022 Posted February 25, 2022 Can you use a lower 1080p bitrate option? Not looking at the options right now but maybe 25 or 30Mvps.
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 What is the exact model of the device? It currently looks like it is reporting that it supports 4K.
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 14 minutes ago, ebr said: What is the exact model of the device? It currently looks like it is reporting that it supports 4K. 3800X. From Roku's hardware specs page, looks like 1080p is the max:
thunderclap 52 Posted February 25, 2022 Author Posted February 25, 2022 21 minutes ago, Happy2Play said: Can you use a lower 1080p bitrate option? Not looking at the options right now but maybe 25 or 30Mvps. I can try to work with him over the weekend as a test and see what happens.
ebr 16334 Posted February 25, 2022 Posted February 25, 2022 Okay, whenever you can get that app log, it will be very helpful in determining why the app thinks it supports 4K.
