mitch2471 11 Posted February 24, 2022 Posted February 24, 2022 I’m giving Emby Theater another try instead of using WMC. I’ve got the WMC server plugin installed. As far as I can see I have set up wmc server correctly. It has the correct network path for my recorded tv folder. It sees my tuners as available & shows the epg download when in operation. In the Emby settings menu my tuner has been recognised & epg downloaded. In the channels section I can see that the correct channels are showing & are mapped. When I go into emby theater I see the same things in the settings, i.e. tuner recognised, epg downloaded & channels showing as mapped. I have also set the default storage locations etc. When I press control G the guide comes up but is unpopulated. No channels showing, no programmes showing. I’m at a loss.
Luke 42234 Posted February 24, 2022 Posted February 24, 2022 HI there, did you run the refresh guide scheduled task? What version of Emby Server?
mitch2471 11 Posted February 24, 2022 Author Posted February 24, 2022 Hi Luke. Thanks for getting back to me. I'm on version 4.6.7. At the risk of sounding dim, where do I find the guide scheduled task? It doesn't seem to be under live tv. The only thing there is the manual epg update which I have done.
mitch2471 11 Posted February 24, 2022 Author Posted February 24, 2022 Found it. It is set to auto update every 24hrs 1
mitch2471 11 Posted February 24, 2022 Author Posted February 24, 2022 Any other suggestions? Still no channels in the guide.
Luke 42234 Posted February 24, 2022 Posted February 24, 2022 4 hours ago, mitch2471 said: Any other suggestions? Still no channels in the guide. I would check parental controls to make sure you don't have any restrictions applied that might cause them to be hidden. If that doesn't lead to anything, then please attach the emby server log. thanks.
Carlo 4561 Posted February 25, 2022 Posted February 25, 2022 @mitch2471 Have you had a chance to try that yet?
mitch2471 11 Posted February 25, 2022 Author Posted February 25, 2022 Nothing set up in parental control. I'll get the server log uploaded asap. cheers guys
mitch2471 11 Posted February 25, 2022 Author Posted February 25, 2022 I've attached the server log, wmc server log & hardware detection log. Emby server, Theater & wmc server are all installed on the same Windows 10 x64 pc. I've also attached screen shots of all the settings I have in the servers & plugins. The last photos show the tv guide in emby theater which is still not showing anything. embyserver.txt hardware_detection-63781384804.txt ServerWMC current log.txt
Luke 42234 Posted February 26, 2022 Posted February 26, 2022 If you run the refresh guide again, is it still empty? Are you behind a vpn by any chance?
mitch2471 11 Posted February 26, 2022 Author Posted February 26, 2022 7 hours ago, Luke said: If you run the refresh guide again, is it still empty? Are you behind a vpn by any chance? Afraid so. I've carried out multiple epg updates over multiple days. No vpn on this machine. I did wonder if it was firewall related or windows streaming related but after switching the firewall off & making sure all Windows file sharing & streaming settings are on, no joy.
mitch2471 11 Posted February 28, 2022 Author Posted February 28, 2022 Yes. It's Windows 10 so as far as I'm aware there is no choice with windows update. I take it that there is nothing showing in the logs or the screen shots that's obviously wrong? I recorded a couple of shows in windows media center towards the end of last week. They show as available to watch in the Emby Theater recordings section of live tv so there is some communication going on between the various services.
mitch2471 11 Posted March 1, 2022 Author Posted March 1, 2022 On 27/02/2022 at 19:48, Luke said: Is Windows fully up to date? Yes. It's Windows 10 so as far as I'm aware there is no choice with windows update. I take it that there is nothing showing in the logs or the screen shots that's obviously wrong? I recorded a couple of shows in windows media center towards the end of last week. They show as available to watch in the Emby Theater recordings section of live tv so there is some communication going on between the various services. Any suggestions?
Luke 42234 Posted March 1, 2022 Posted March 1, 2022 Can you show a screenshot of the emby user permissions for that user? thanks.
mitch2471 11 Posted March 1, 2022 Author Posted March 1, 2022 2 hours ago, Luke said: Can you show a screenshot of the emby user permissions for that user? thanks. Where about's do I find that? In the Emby Server under users it just shows one user listed as primary. I could not see anything listed as permissions.
mitch2471 11 Posted March 1, 2022 Author Posted March 1, 2022 2 hours ago, Luke said: Can you show a screenshot of the emby user permissions for that user? thanks. Disregard the last message. I have not ever clicked on the user button itself in the user section of the server so I have not ever seen the permissions section before. And I thought I new Emby server fairly well after all these years! In permissions under live tv were two empty tick boxes. I have ticked them, saved & restarted the server & low & behold….live tv now works. Sorry to be a pain & I appreciate your help. On a side note I saw the notice/reminder about Windows Media Center support coming to an end. Would it be possible for you to post a link for a download of the most recent Emby Server & Windows Media Centre installer application for an offline install? If any of us wanted to say do an operating system re-install or change after support ends your download installer will offer the most recent server which may not at that time be compatible with Windows Media Center & there won’t be an option to download the Windows Media Center app. @ebr 1
