Hispanico957 23 Posted February 23, 2022 Posted February 23, 2022 (edited) My server emby is on my lan with ip 192.168.0.100 Some my friends conncet using Emby Connect and not problem..but sometime I would like to connect some friend giving my WAN eg. http://95.137.20.12:8096 but this ip is dynamic and some day is different. For my computer i use for this DYNDNS.IT with name hispaxxx.homepc.it, but to conncet to emby on my nas in which way i can use same method ? ie giving a name to my server emby so even if the ip changes you can connect the same? I hope I have explained ANd if is possible where i can store the information of ddns on config of emby Thank Hispa Edited February 23, 2022 by Hispanico957
Solution Happy2Play 9811 Posted February 23, 2022 Solution Posted February 23, 2022 You can put hispaxxx.homepc.it in External Domain. But from a WAN address standpoint that is the purpose of Connect as it will auto update your detected address. 1
