Bytechanger 0 Posted February 22, 2022 Posted February 22, 2022 (edited) Hi, I´m using Emby in an proxmox-Docker container. VU+ -> VTI-Image with HRTunerProxy. In Enigma includet., All channels are shown correctly, but when I start stream message "no compatible stream..." (in german) is shown. What´s wrong? Logs here 2022-02-22 07:00:00.077 Info HttpClient: GET http://172.30.90.XX:6083/discover.json 2022-02-22 07:00:00.123 Info HttpClient: GET http://172.30.90.XX:6083/lineup.json 2022-02-22 07:00:00.474 Info App: User policy for Andreas. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-02-22 07:00:00.559 Info LiveTvManager: Opening channel stream from Emby, external channel Id: hdhr_1 2022-02-22 07:00:00.562 Info LiveTV: Streaming Channel hdhr_1 2022-02-22 07:00:00.570 Info HdHomerunHost: GetChannelStream: channel id: hdhr_1. stream id: native_3296d406dcc9cb9b62aeaef99612ba6b_4890a0be7a279973dc70c72e56f6370b profile: native 2022-02-22 07:00:00.576 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://172.30.90.XX:8001/1:0:19:283D:3FB:1:C00000:0:0:0: 2022-02-22 07:00:00.576 Info HttpClient: GET http://172.30.90.XX:8001/1:0:19:283D:3FB:1:C00000:0:0:0: 2022-02-22 07:00:00.583 Info HttpClient: Http response 401 from http://172.30.90.XX:8001/1:0:19:283D:3FB:1:C00000:0:0:0: after 6ms. HeadersWWW-Authenticate=Basic realm="OpenWebif" 2022-02-22 07:00:00.596 Error HdHomerunHost: Error opening tuner *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-99-generic (buildd@lgw01-amd64-007) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #112-Ubuntu SMP Thu Feb 3 13:50:55 UTC 2022 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken, Int32 recursion) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.Open(CancellationToken openCancellationToken) at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannelStream(String channelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2022-02-22 07:00:00.605 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-99-generic (buildd@lgw01-amd64-007) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #112-Ubuntu SMP Thu Feb 3 13:50:55 UTC 2022 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system MediaBrowser.Controller.LiveTv.LiveTvConflictException: MediaBrowser.Controller.LiveTv.LiveTvConflictException: Exception of type 'MediaBrowser.Controller.LiveTv.LiveTvConflictException' was thrown. at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannelStream(String channelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(String channelId, String streamId, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvMediaSourceProvider.OpenMediaSource(String openToken, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStream(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.OpenMediaSource(OpenMediaSource request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(GetPostedPlaybackInfo request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetPostedPlaybackInfo request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.LiveTV TargetSite: Void MoveNext() hm, cloud this the problem? Where can I set authorisation-data MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized Greets Byte Edited February 22, 2022 by Bytechanger
Luke 42243 Posted February 22, 2022 Posted February 22, 2022 Hi, looks like the channel URL to the proxy is returning a 401 unauthorized response. Can you look into that?
Bytechanger 0 Posted February 23, 2022 Author Posted February 23, 2022 (edited) Hi, I´ve to set "authenticate for stream" OFF, so it works. But is there a way to stream with username/password? And can I set a transcode mode for less bandwich? Greets Byte Edited February 23, 2022 by Bytechanger
Luke 42243 Posted February 23, 2022 Posted February 23, 2022 7 hours ago, Bytechanger said: Hi, I´ve to set "authenticate for stream" OFF, so it works. But is there a way to stream with username/password? And can I set a transcode mode for less bandwich? Greets Byte Only if you can make the username and password part of the URL. Who has less bandwidth, emby server, or the emby client app?
