Guest Posted February 19, 2022 Posted February 19, 2022 (edited) Hello, I noticed some of my movies (personally encoded in Handbrake) are manifesting an interesting "phenomena" .. to put it bluntly. Dashboard says the following: Quote The media is compatible with the device regarding resolution and media type (H.264, AC3, etc.), but is in an incompatible file container (.mkv, .avi, .wmv, etc.). The video will be re-packaged on the fly before streaming it to the device. Direct Streaming a file uses very little processing power without any loss in video quality. I always encode stuff to avoid transcoding, for home/LAN use as well as for remote streaming. So you can imagine how surprised I was (especially when Plex and Jellyfin play affected movies without any issue). ffmpeg-remux file is included. What strikes me is the following: >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Copy video stream >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info VideoOutput >> False False Not a hardware encoder Info Copy video stream >> False False Software Codec Right now I'm subcribed to Premiere, right now for a month only (I'm in the middle of transition from Plex to .. something else, so it is a kind of testing flight, but Emby seems to be a winner). If I read it right, the above says there is no HW decoding available, which is strange as it is enabled... Server is up-to-date 4.6.7.0 running on Ubuntu 18.04 LTS, client is Nvidia Shield on up-to-date image (Shield Experience 9.0.1). Thank you ffmpeg-remux-ec764620-384e-4cf8-87ea-011851aa8c7b_1.txt Edited February 19, 2022 by gabbercon Typos corrected
Guest Posted February 19, 2022 Posted February 19, 2022 vainfo libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_1 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.1 (libva 2.1.0) vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Mobile - 2.1.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD Â
Luke 42245 Posted February 19, 2022 Posted February 19, 2022 Hi, there's no hardware decoding because in this transcoding session there is no decoding or encoding occurring. It is simply passing through the original video untouched. So why is it doing this in the first place and not direct playing? According to the log the app first tried to direct play, then had an error with the file and automatically switched to repackaging it on the server to ensure successful playback.
Guest Posted February 19, 2022 Posted February 19, 2022 (edited) I still have the "untouched" (audio-wise) version of video file in question with DTS-MA audio track. That version plays fine, no problem. However, with FLAC audio track it fails to direct play. I picked randomly some previously added movies with FLAC audio tracks and they fail to direct play almost immediately. Makes no sense. Mediainfo output (without chapters info) General Unique ID : 285069472975386545091207929862607614728 (0xD6766228092D02D8DBEC47E38C183308) Complete name : /media/NAS414/Plex/Movies/Predator (1987)/Predator (1987) - Home.mkv Format : Matroska Format version : Version 4 File size : 8.27 GiB Duration : 1 h 46 min Overall bit rate mode : Variable Overall bit rate : 11.1 Mb/s Movie name : Predator (1987) Encoded date : UTC 2022-02-19 08:40:46 Writing application : mkvmerge v64.0.0 ('Willows') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.3 / Lavf58.29.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings : CABAC / 16 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 16 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 46 min Bit rate : 7 917 kb/s Width : 1 920 pixels Height : 1 040 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.165 Stream size : 5.89 GiB (71%) Writing library : x264 core 160 r3011 cde9a93 Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : FLAC Format/Info : Free Lossless Audio Codec Codec ID : A_FLAC Duration : 1 h 46 min Bit rate mode : Variable Bit rate : 1 681 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 10.417 FPS (4608 SPF) Bit depth : 16 bits Compression mode : Lossless Stream size : 1.25 GiB (15%) Language : English Default : Yes Forced : No Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1 h 46 min Bit rate mode : Constant Bit rate : 1 510 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.12 GiB (14%) Language : Czech Default : No Forced : No  Edited February 19, 2022 by gabbercon Typos corrected. Added info.
Luke 42245 Posted February 19, 2022 Posted February 19, 2022 Can you try sideloading our standard android app onto the Shield and let us know how it compares with that? https://emby.media/emby-for-android.html Thanks.
Guest Posted February 19, 2022 Posted February 19, 2022 Sure I can. Sideloaded and it plays fine - in direct play mode (as it should).
Solution Luke 42245 Posted February 19, 2022 Solution Posted February 19, 2022 1 hour ago, gabbercon said: Sure I can. Sideloaded and it plays fine - in direct play mode (as it should). That's great info, and that's also good news for our tv app because ultimately it will get updated with the same changes. Thanks.
Guest Posted February 19, 2022 Posted February 19, 2022 Just now, Luke said: That's great info, and that's also good news for our tv app because ultimately it will get updated with the same changes. Thanks. Great! All I need to do now is just wait for next release of Android TV app right? As long as this "repackaging" thing does not cause any harm to video quality I'm fine (I know it doesn't). I must say it feels great to contribute, I mean to provide a feedback, either positive or negative in order to improve the product in general. In other words, thanks.
Luke 42245 Posted February 21, 2022 Posted February 21, 2022 Quote Great! All I need to do now is just wait for next release of Android TV app right? Yes that is correct. Thanks for the feedback.
Guest Posted February 26, 2022 Posted February 26, 2022 (edited) This "repackaging" in reality means that FLAC audio is being transcoded to Dolby Digital whenever I'm watching a movie with FLAC audio track. I only found out by accident, as I have had off the option to show what decoder my AVR uses. Now it shows the codec being used and I was not pleased to see Dolby Digital on my AVR at all. Not that DD is bad, but transcoding is always bad, in my book at least. Edited February 26, 2022 by gabbercon added info and typos
ebr 16337 Posted February 26, 2022 Posted February 26, 2022 12 hours ago, gabbercon said: I only found out by accident, Hi. So, that means you couldn't tell the difference with your ear? 12 hours ago, gabbercon said: but transcoding is always bad, in my book at least. Why? Virtually everything you play is being encoded/decoded at multiple levels in that playback process.
Guest Posted February 26, 2022 Posted February 26, 2022 (edited) 1 hour ago, ebr said: Hi. So, that means you couldn't tell the difference with your ear? Why? Virtually everything you play is being encoded/decoded at multiple levels in that playback process. No I couldn't because I have been using (testing) Emby this month only, movies I finished watching didn't have FLAC audio. And I didn't finish movies where Emby started "repackaging". It does not repackage anything it randomly starts transcoding from lossless to lossy. And when it does the spinning circle appears and the movie pauses for a moment. Let's call it a distruption you would notice right away. As you do, you start troubleshooting what's going on and pay little attention whether you can hear it. Edited February 26, 2022 by gabbercon
