jhowetan 1 Posted February 19, 2022 Posted February 19, 2022 (edited) Hello, I'm trying to run Emby through Portainer but I am having issues. I've attached the container log and the content of the stack. Thanks in advance! emby_stack.txt _emby_logs.txt Edited February 19, 2022 by jhowetan
CassTG 113 Posted February 19, 2022 Posted February 19, 2022 (edited) Just a cpl of questions Does the PUID and PGID match the owners of the folders your mapping. i.e which non root user are you using and what is it's ids on host system id username Portainer is just a frontend to manage docker, and as thats just a single docker and not a stack have you tried via cli. Also reference the volumes are they locally mounted drives just curious why the long character references, the config one i normally leave in var (where docker volumes and images are stored by default normally) for persitant storage so is their any reason to be placing in srv. Edited February 19, 2022 by CassTG
jhowetan 1 Posted February 19, 2022 Author Posted February 19, 2022 Hello, Thanks for your reply! Yes the PUID and PGID match. The long character references are because it's a pooled drive. My old boot drive failed recently so I'm booting off a new one. The config, TV and movie folders were already on my storage drives. After deleting the container and deploying the stack several times, it is working now. I'm not sure what went wrong...The only difference is instead of /data/tvshows I changed it to /data/tv shows Everything else is the same.
