Neminem 1623 Posted January 10, 2025 Posted January 10, 2025 (edited) Well that is logical. There are many factors involved in this. VPN usage, CGnat, cell tower location and more jazz. And on top of that PC don't have a GPS chip in them that is precise enough. If the user uses a phone, they might not have enable location. Or are behind VPN usage, CGnat, cell tower location and more jazz. But how are the exporter supposed to know that, as it only gets what Emby knows. And that is a IP address ( behind VPN usage, CGnat, cell tower location and more jazz. ) @cochize1 Edited January 10, 2025 by Neminem
cochize1 55 Posted January 10, 2025 Posted January 10, 2025 Yeah, I thought about all that as well BUT, checking the same IP on any IP finder site gives a correct location. And I only check the obvious cases out of curiosity. Say, I see a friend watching a movie at his home on his Samsung TV (95% sure he is not using any VPN or hotspot from his cell) and exporter says he is in other city (but the IP finder sites give correct location).
Bagul 182 Posted January 10, 2025 Author Posted January 10, 2025 1 hour ago, cochize1 said: When redeploying the stack in Portainer that had Emby Exporter in it I get this error in the logs: 19:28:35 | INFO | main.go:37 > Using Europe/Warsaw 19:28:35 | INFO | logger.go:107 > Server is not reachable 19:29:37 | INFO | main.go:37 > Using Europe/Warsaw 19:29:37 | INFO | logger.go:107 > Server is not reachable 19:30:40 | INFO | main.go:37 > Using Europe/Warsaw 19:30:40 | INFO | logger.go:107 > Server is not reachable In the same stack I have some other containers that work just fine after redeploying. What could be the problem as my knowledge is quite limited and all I can do is all hit and miss trial and error guessing? I'm sorry, it's my fault. I've created a new version which normally fixes the problem if the server url starts with https.
Bagul 182 Posted January 10, 2025 Author Posted January 10, 2025 1 minute ago, cochize1 said: Yeah, I thought about all that as well BUT, checking the same IP on any IP finder site gives a correct location. And I only check the obvious cases out of curiosity. Say, I see a friend watching a movie at his home on his Samsung TV (95% sure he is not using any VPN or hotspot from his cell) and exporter says he is in other city (but the IP finder sites give correct location). When creating the docker image, I retrieve a database for geolocation so as not to use an external service (for reasons of confidentiality and I don't want the service to stop working one day). Over time, geolocation may diverge from reality, as some operators don't deliver a fixed ip but a dynamic ip.
cochize1 55 Posted January 10, 2025 Posted January 10, 2025 So basically the data for IP location is fixed and is not being updated overtime? And there is no workaround for that? And also, is it being updated with every new image pull of the exporter?
Bagul 182 Posted January 10, 2025 Author Posted January 10, 2025 5 minutes ago, cochize1 said: So basically the data for IP location is fixed and is not being updated overtime? And there is no workaround for that? And also, is it being updated with every new image pull of the exporter? Yes, the database is local and is only updated with a new version of the exporter. I'd look into retrieving the information in another way, or updating the database directly in the exporter if you like.
cochize1 55 Posted January 10, 2025 Posted January 10, 2025 Well, I just found out today that you're not planning on releasing new versions since you don't use Emby anymore BUT please do now that we appreciate what you have done for us so far. So if you could poke around and find a solution for that one last issue (we have noticed) just for the kicks of it I personally would like that very much:)
cochize1 55 Posted January 11, 2025 Posted January 11, 2025 Any idea why it stopped working again overnight? I keep getting the same error: 11:41:13 | INFO | logger.go:107 > Server is not reachable
Neminem 1623 Posted January 11, 2025 Posted January 11, 2025 @cochize1if you use this bagul/goemby_exporter:v1.0.11 You are back in business, but with out the fix to tv shows spill over. @BagulThanks for the update, the fix to https broke http and https. 1
Bagul 182 Posted January 11, 2025 Author Posted January 11, 2025 1 hour ago, Neminem said: @cochize1if you use this bagul/goemby_exporter:v1.0.11 You are back in business, but with out the fix to tv shows spill over. @BagulThanks for the update, the fix to https broke http and https. Ah, sorry, maybe I was more tired than I thought I've fixed the problem, I can't create a new release now, but I'll take care of it tomorrow. 1
Neminem 1623 Posted January 11, 2025 Posted January 11, 2025 @cochize1You really need to learn to use GitHub. When you have issues, with 3th party dev's. Its likely they don't monitor forum messageres. 1
Neminem 1623 Posted January 13, 2025 Posted January 13, 2025 @cochize1There is a new update. You can again use latest docker tag.... bagul/goemby_exporter:latest @BagulThank you for the fix 1
Bagul 182 Posted January 13, 2025 Author Posted January 13, 2025 10 minutes ago, Neminem said: @cochize1There is a new update. You can again use latest docker tag.... bagul/goemby_exporter:latest @BagulThank you for the fix Yes, I've deployed the fix. I'll look into updating the geolocation database. 1
cochize1 55 Posted January 13, 2025 Posted January 13, 2025 12 minutes ago, Bagul said: Yes, I've deployed the fix. I'll look into updating the geolocation database. Great, I'll be looking into this, thanks again
jleiss 0 Posted February 23, 2025 Posted February 23, 2025 I understand this is no longer mainted, but question about the capturing of data, is that only able be pulled from the local docker environment, or can it grab stuff from anywhere
Neminem 1623 Posted February 23, 2025 Posted February 23, 2025 No you should be able to point your prometheus config to pull the exporter data on a different pc / server.
jleiss 0 Posted February 23, 2025 Posted February 23, 2025 5 minutes ago, Neminem said: No you should be able to point your prometheus config to pull the exporter data on a different pc / server. it appears to be working but prometheus cannot pull the data. This is what I am seeing, where 172.17.0.2 is the exporter
Neminem 1623 Posted February 23, 2025 Posted February 23, 2025 Is that on a different pc, if it is then you cant use docker ip range. Use server/host ip
Neminem 1623 Posted February 23, 2025 Posted February 23, 2025 This is from a different host where I pull iGPU stats.
jleiss 0 Posted February 23, 2025 Posted February 23, 2025 1 minute ago, Neminem said: Is that on a different pc, if it is then you cant use docker ip range. Use server/host ip No exporter and prometheus are on the same host, only emby is in a different location. I am querying the docker IP this is my prometheus job - job_name: 'emby-exporter' scrape_interval: 15s static_configs: - targets: ['172.17.0.2:9210']
Neminem 1623 Posted February 23, 2025 Posted February 23, 2025 What's the output in your exporter logs ?
jleiss 0 Posted February 23, 2025 Posted February 23, 2025 I get target refused when using the machine IP exporter logs jleiss@bree:/opt/prometheus$ docker logs emby_exporter 10:46:36 | INFO | main.go:37 > Using America/Chicago 10:46:36 | INFO | app.go:56 > Beginning to serve on port 9210 10:46:36 | INFO | app.go:57 > You can see the metrics on http://localhost:9210/metrics 11:08:00 | INFO | main.go:37 > Using America/Chicago 11:08:00 | INFO | app.go:56 > Beginning to serve on port 9210 11:08:00 | INFO | app.go:57 > You can see the metrics on http://localhost:9210/metrics 11:15:02 | INFO | main.go:37 > Using America/Chicago 11:15:02 | INFO | app.go:56 > Beginning to serve on port 9210 11:15:02 | INFO | app.go:57 > You can see the metrics on http://localhost:9210/metrics
