Skyfay 19 Posted February 18, 2022 Posted February 18, 2022 If you search Emby and you have a >'< in the title, you won't find him if you omit the >'<. Example: Titel in Emby: The King’s Man if you search for: The Kings Man emby can't find the movie. You really have to put the >'< sign to find the movie. Can emby regulate this differently?
GrimReaper 4902 Posted February 18, 2022 Posted February 18, 2022 Not sure what you're asking there, why wouldn't you put " ' " when searching, it's a single keystroke away? As "King's" is not same as "Kings", why should they be synonyms?
Skyfay 19 Posted February 18, 2022 Author Posted February 18, 2022 (edited) 4 minutes ago, GrimReaper said: Not sure what you're asking there, why wouldn't you put " ' " when searching, it's a single keystroke away? As "King's" is not same as "Kings", why should they be synonyms? If I am a user, then I may not know that there is an " ' " coming. So I'm then in the belief that this film does not exist. I've searched a lot and couldn't find it because " ' "... Would be cool if similar content could somehow be included with " ' , . - " Etc. Edited February 18, 2022 by Skyfay
Luke 42246 Posted February 18, 2022 Posted February 18, 2022 Hi, yes it's something that can be improved. Thanks. 1
