lowe1739 3 Posted February 17, 2022 Posted February 17, 2022 Whenever I add a new episode of a tv show and identify it. It overrides any images I have added it, wiping it out and causing me to have to added it back each time. How do i keep it from doing this every time I added new content It doesn't matter if the box to replace is selected or not. I searched a few keywords for image issue but didn't see this topic please link to one if it already exist.
GrimReaper 4854 Posted February 17, 2022 Posted February 17, 2022 (edited) 43 minutes ago, lowe1739 said: Whenever I add a new episode of a tv show and identify it Why would you identify it every time? Single Identify on TV show level is enough. Afterwards regular Scan (either RTS enabled or three-dot menu Scan library files or Scan media library task scheduled/manual) will suffice. Edited February 17, 2022 by GrimReaper Typo
Luke 42186 Posted February 17, 2022 Posted February 17, 2022 1 hour ago, lowe1739 said: Whenever I add a new episode of a tv show and identify it. It overrides any images I have added it, wiping it out and causing me to have to added it back each time. How do i keep it from doing this every time I added new content It doesn't matter if the box to replace is selected or not. I searched a few keywords for image issue but didn't see this topic please link to one if it already exist. Hi, I don't quite understand. Why did you select "replace existing images" if you didn't want that to happen?
lowe1739 3 Posted February 18, 2022 Author Posted February 18, 2022 3 hours ago, Luke said: Hi, I don't quite understand. Why did you select "replace existing images" if you didn't want that to happen? it doesn't matter either if i select or i don't select that just a pic to help so you know what i'm takling about. If un check that box it still wipes the image for the TV show and i have to add it back in.
lowe1739 3 Posted February 18, 2022 Author Posted February 18, 2022 3 hours ago, GrimReaper said: Why would you identify it every time? Single Identify on TV show level is enough. Afterwards regular Scan (either RTS enabled or three-dot menu Scan library files or Scan media library task scheduled/manual) will suffice. Because it doesn't pull down the data and sync to the existing tv series i already have going until I use Identify . Scanning the library does not sync into the existing series for me if it cant identify the file.
GrimReaper 4854 Posted February 18, 2022 Posted February 18, 2022 (edited) 7 minutes ago, lowe1739 said: Because it doesn't pull down the data and sync to the existing tv series i already have going until I use Identify Then something is seriously off with your setup. Do you have RTM enabled? If so, next time you add an episode - and you can see it being added - post a server log. If you don't have RTM enabled, next time you add an episode trigger manual scan and post the server log afterwards. Edited February 18, 2022 by GrimReaper Typo
Happy2Play 9801 Posted February 18, 2022 Posted February 18, 2022 I am confused here as you do not identify a episode when it is added. A series is identified and then the episode info is gotten from that already identified Series. Can you go over exactly what you are doing for a specific example.
pwhodges 2025 Posted February 18, 2022 Posted February 18, 2022 11 hours ago, lowe1739 said: Whenever I add a new episode of a tv show and identify it If you have to identify manually every time, then I can only assume that you are using a folder and file naming scheme which is not supported by Emby. Seeing that naming scheme would help us suggest what changes would fix this. Paul
lowe1739 3 Posted February 18, 2022 Author Posted February 18, 2022 11 hours ago, GrimReaper said: Then something is seriously off with your setup. Do you have RTM enabled? If so, next time you add an episode - and you can see it being added - post a server log. If you don't have RTM enabled, next time you add an episode trigger manual scan and post the server log afterwards. How do i check to see if RTM is enabled?
lowe1739 3 Posted February 18, 2022 Author Posted February 18, 2022 5 hours ago, pwhodges said: If you have to identify manually every time, then I can only assume that you are using a folder and file naming scheme which is not supported by Emby. Seeing that naming scheme would help us suggest what changes would fix this. Paul Here is a folder example and a show example...do i need to keep all the shows in the same sub folder?
lowe1739 3 Posted February 18, 2022 Author Posted February 18, 2022 3 minutes ago, lowe1739 said: How do i check to see if RTM is enabled? I found it and it is enabled on the libraries
GrimReaper 4854 Posted February 18, 2022 Posted February 18, 2022 2 minutes ago, lowe1739 said: Here is a folder example and a show example...do i need to keep all the shows in the same sub folder? Under those top folders, do you have a subfolder for each show, as per KB article? Emby TV Naming : Emby 1
lowe1739 3 Posted February 18, 2022 Author Posted February 18, 2022 21 minutes ago, GrimReaper said: Under those top folders, do you have a subfolder for each show, as per KB article? Emby TV Naming : Emby nope that appears to be what i've been doing wrong this entire time. 1
Happy2Play 9801 Posted February 18, 2022 Posted February 18, 2022 7 hours ago, GrimReaper said: 8 hours ago, lowe1739 said: Here is a folder example and a show example...do i need to keep all the shows in the same sub folder? Under those top folders, do you have a subfolder for each show, as per KB article? Emby TV Naming : Emby 7 hours ago, lowe1739 said: nope that appears to be what i've been doing wrong this entire time. Sorry but can you expand on TV folder content as we can't tell, but would suggest you have a generic folder of episodes which is not supported.
Luke 42186 Posted February 19, 2022 Posted February 19, 2022 Yes how exactly are your files named and organized?
lowe1739 3 Posted February 19, 2022 Author Posted February 19, 2022 1 hour ago, Luke said: Yes how exactly are your files named and organized? Well I've made a 2nd level folder now for all the shows. But I typically leave everything named as it is already...I'll try to post a screen cap in the next day or so. But it is working now that I've added the 2nd level folder so it goes ...TV-show name-show episode
lowe1739 3 Posted February 21, 2022 Author Posted February 21, 2022 On 2/19/2022 at 2:46 PM, Luke said: Thanks for the feedback. see pics
lowe1739 3 Posted March 1, 2022 Author Posted March 1, 2022 @Luke I am yes, thank you for the help. I have been using Emby for good while not but never really went through best setup for it. the community has been a great help even for basic's like this! 1
