H00pes4908 3 Posted February 17, 2022 Posted February 17, 2022 Every time I try a dumb conversion, it goes through the process, and then the file disappears and never shows in my library. When I go back to conversion history it just says "ready for transfer" No idea what is wrong always worked fine when doing this with plex. embyserver.txt
Luke 42243 Posted February 18, 2022 Posted February 18, 2022 HI, looks like you setup a conversion job to convert and move the new files into your media folders, but you did not ensure that emby server has sufficient write access to do that: 2022-02-17 13:27:15.137 Error App: Error transferring sync job file *** Error Report *** Version: 4.6.7.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #42218 SMP Mon Oct 18 19:16:55 CST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied. ---> System.IO.IOException: Operation not permitted --- End of inner exception stack trace --- at System.IO.FileSystem.CopyFile(String sourceFullPath, String destFullPath, Boolean overwrite) at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite) at Emby.Server.Implementations.IO.ManagedFileSystem.CopyFile(String source, String target, Boolean overwrite) 1
H00pes4908 3 Posted February 18, 2022 Author Posted February 18, 2022 57 minutes ago, Luke said: HI, looks like you setup a conversion job to convert and move the new files into your media folders, but you did not ensure that emby server has sufficient write access to do that: 2022-02-17 13:27:15.137 Error App: Error transferring sync job file *** Error Report *** Version: 4.6.7.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #42218 SMP Mon Oct 18 19:16:55 CST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied. ---> System.IO.IOException: Operation not permitted --- End of inner exception stack trace --- at System.IO.FileSystem.CopyFile(String sourceFullPath, String destFullPath, Boolean overwrite) at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite) at Emby.Server.Implementations.IO.ManagedFileSystem.CopyFile(String source, String target, Boolean overwrite) Hmm, ok well how do I do that? I checked and looked like all the permissions were set.
Luke 42243 Posted February 18, 2022 Posted February 18, 2022 6 minutes ago, H00pes4908 said: Hmm, ok well how do I do that? I checked and looked like all the permissions were set. What and where did you check? 1
H00pes4908 3 Posted February 18, 2022 Author Posted February 18, 2022 (edited) 2 minutes ago, Luke said: What and where did you check? In the shared folders the file should be going into Edited February 18, 2022 by H00pes4908
Luke 42243 Posted February 18, 2022 Posted February 18, 2022 Are you sure you configured it for the right folders? (the ones containing the files being converted). 1
Carlo 4561 Posted February 21, 2022 Posted February 21, 2022 Can you show us a screen shot of the permissions for the share this media is on?
