Davey's 40 Posted February 17, 2022 Posted February 17, 2022 Hi on my LG It is almost impossible to play 4k content on my c9 LG tv Therefore I would like to check the current status of the maximum bitrate capabilities, can this be builded-in the new app?
SamES 1084 Posted February 18, 2022 Posted February 18, 2022 Can you provide more information and an example? I suspect you are playing a TrueHD or DTS track on a device that doesn't support it. This will cause the audio to be converted and the file to be delivered via DirectStream which does not work well for high bitrate 4K/HEVC files. Try changing to an AC3 track and see if that fixes the issue.
Davey's 40 Posted February 18, 2022 Author Posted February 18, 2022 Will try that, van i manage these from the Emby dashboard ?
SamES 1084 Posted February 19, 2022 Posted February 19, 2022 Select the AC3 audio track from the details screen for the movie, before you press play.
