0v3rl0rd 5 Posted February 17, 2022 Posted February 17, 2022 Hi. I've set up a Raspberry Pi 4 with an external 4TB HDD. It's running Raspberry OS Lite (Debian GNU/Linux 11, bullseye), with installed Docker and Emby server in it - it's all working well for direct streaming to my LG C1. About SUBTITLES - I always do this manually - find them and put them in the same folder where the movie file is. About IMAGES and other info - I don't have any images, covers, etc. I only have movie+subtitle files, nothing else. All the extra data which Emby creates automatically when creating a library (nfo metadata files, covers, actor images, etc.) I'd like to have it in separate folder of my choice. I "played" a little when creating a test library. But I cannot seem to find the solution. 1) NFO files: When creating a library, if I enable "metadata savers", it saves the NFO's in same folder that the media is located. When leaving the "metadata savers" disabled, I have no idea where it stores the NFO's files. 2) IMAGES: When creating a library, if I enable "save artwork into media folders", it save the images in same folder that the media is located. When leaving the "save artwork into media folders" disabled, I have no idea where it stores the image files. I'd like to have my files that I manually downloaded (media+subtitles) intact, AS IS, without any extra info in the same folder - all the NFOs, covers, etc. in one folder (to rule them all ). Inside that "one" folder I don't mind having subfolders My media structure is simple like this: MOVIES: \movies\air_america_1990\avatar_2009.mkv \movies\air_america_1990\avatar_2009.srt \movies\atlantis_the_lost_continent_1961\atlantis_the_lost_continent_1961.mkv \movies\atlantis_the_lost_continent_1961\atlantis_the_lost_continent_1961.srt \movies\the_kings_man_2021\the_kings_man_2021.mp4 \movies\the_kings_man_2021\the_kings_man_2021.srt \movies\mortdecai_2015\mortdecai_2015.mkv \movies\mortdecai_2015\mortdecai_2015.srt \movies\elysium_2013\elysium_2013.mkv \movies\elysium_2013\elysium_2013.srt SERIES: \series\loki_2021\loki_s01e01_glorious_purpose.mp4 \series\loki_2021\loki_s01e01_glorious_purpose.srt \series\loki_2021\loki_s01e02_the_variant.mp4 \series\loki_2021\loki_s01e02_the_variant.srt \series\loki_2021\loki_s01e03_lamentis.mp4 \series\loki_2021\loki_s01e03_lamentis.srt ... etc ... \series\the_it_crowd\the_it_crowd_s01e01.mkv \series\the_it_crowd\the_it_crowd_s01e01.srt \series\the_it_crowd\the_it_crowd_s01e02.mkv \series\the_it_crowd\the_it_crowd_s01e02.srt \series\the_it_crowd\the_it_crowd_s02e01.mkv \series\the_it_crowd\the_it_crowd_s02e01.srt \series\the_it_crowd\the_it_crowd_s02e02.mkv \series\the_it_crowd\the_it_crowd_s02e02.srt \series\the_it_crowd\the_it_crowd_s03e01.mkv \series\the_it_crowd\the_it_crowd_s03e01.srt \series\the_it_crowd\the_it_crowd_s04e01.mkv \series\the_it_crowd\the_it_crowd_s04e01.srt ... etc ... Any help appreciated
Solution GrimReaper 4926 Posted February 17, 2022 Solution Posted February 17, 2022 1 minute ago, 0v3rl0rd said: 1) NFO files: When creating a library, if I enable "metadata savers", it saves the NFO's in same folder that the media is located. When leaving the "metadata savers" disabled, I have no idea where it stores the NFO's files. Nowhere. It's either NFOs with media or no NFOs/db only. 1 minute ago, 0v3rl0rd said: 2) IMAGES: When creating a library, if I enable "save artwork into media folders", it save the images in same folder that the media is located. When leaving the "save artwork into media folders" disabled, I have no idea where it stores the image files. To \metadata folder, your Dashboard should tell you where that path is (or if you customized it under Settings>Library>Advanced tab). 1
0v3rl0rd 5 Posted February 17, 2022 Author Posted February 17, 2022 3 hours ago, GrimReaper said: Nowhere. It's either NFOs with media or no NFOs/db only. To \metadata folder, your Dashboard should tell you where that path is (or if you customized it under Settings>Library>Advanced tab). It's a pity that's not possible that for NFOs. Two question though: 1. By "db only" I suppose that You mean that the "NFO" data is than stored in the database somewhere, right? Where is that database located than? I just want to know the location of it 2. Thank You for the "Settings>Library>Advanced tab" suggestion. That work like a charm for the images. But, is there any logic behind the weird naming scheme for folders&files that Emby automatically creates? What I mean is, it looks like it's giving random numbers/letters/names to folders and image files: Z:\METADATA\metadata\library\0b\0b12f4436fc8382d9bfc2bab62da0fa8\clearlogo.png Z:\METADATA\metadata\library\0b\0b12f4436fc8382d9bfc2bab62da0fa8\fanart.jpg Z:\METADATA\metadata\library\0b\0b12f4436fc8382d9bfc2bab62da0fa8\landscape.jpg Z:\METADATA\metadata\library\0b\0b12f4436fc8382d9bfc2bab62da0fa8\poster.jpg Z:\METADATA\metadata\library\0b\0b18149353c9dfbcecd0c23e071dd60a\clearlogo.png Z:\METADATA\metadata\library\0b\0b18149353c9dfbcecd0c23e071dd60a\fanart.jpg Z:\METADATA\metadata\library\0b\0b18149353c9dfbcecd0c23e071dd60a\landscape.jpg Z:\METADATA\metadata\library\0b\0b18149353c9dfbcecd0c23e071dd60a\poster.jpg Z:\METADATA\metadata\library\0b\0b1c13c4b6b138d7ef7526132d85510a\fanart.jpg Z:\METADATA\metadata\library\0b\0b1c13c4b6b138d7ef7526132d85510a\poster.jpg Z:\METADATA\metadata\library\0b\0b4d7c7af8564621905ffeddf251b1f6\poster.jpg Z:\METADATA\metadata\library\0b\0b54467a89768112d7e05717918e878d\poster.jpg Z:\METADATA\metadata\library\0b\0b81fb88757a5f2c67629200fb5093e3\poster.jpg Z:\METADATA\metadata\library\0b\0b9f818ce66438912d8845e947048a75\poster.jpg Z:\METADATA\metadata\library\0b\0bb8c583cf829b754a771590de7595bf\poster.jpg Z:\METADATA\metadata\library\0b\0bc1de4a00c0dbfdcf6850644bad8994\poster.jpg Z:\METADATA\metadata\library\0b\0bcca5a2502d89da8b0f3fdb3dfa26e5\clearlogo.png Z:\METADATA\metadata\library\0b\0bcca5a2502d89da8b0f3fdb3dfa26e5\fanart.jpg Z:\METADATA\metadata\library\0b\0bcca5a2502d89da8b0f3fdb3dfa26e5\landscape.jpg Z:\METADATA\metadata\library\0b\0bcca5a2502d89da8b0f3fdb3dfa26e5\poster.jpg
GrimReaper 4926 Posted February 17, 2022 Posted February 17, 2022 44 minutes ago, 0v3rl0rd said: 1. By "db only" I suppose that You mean that the "NFO" data is than stored in the database somewhere, right? Where is that database located than? I just want to know the location of it In \data folder, should be something like /var/lib/emby-server/data or /var/lib/emby/data. 47 minutes ago, 0v3rl0rd said: 2. Thank You for the "Settings>Library>Advanced tab" suggestion. That work like a charm for the images. But, is there any logic behind the weird naming scheme for folders&files that Emby automatically creates? Nope, there is no semantic linking. 1
0v3rl0rd 5 Posted February 17, 2022 Author Posted February 17, 2022 1 minute ago, GrimReaper said: In \data folder, should be something like /var/lib/emby-server/data or /var/lib/emby/data. Nope, there is no semantic linking. Yep, I tought so, that there's no semantic linking. Anyway, thank You for Your help, really appreciate it :) 1
mixXxim 2 Posted February 26, 2022 Posted February 26, 2022 how can I achieve that the nfo files are rewritten into the xxx.mkv directory. Thanks
GrimReaper 4926 Posted February 26, 2022 Posted February 26, 2022 42 minutes ago, mixXxim said: how can I achieve that the nfo files are rewritten into the xxx.mkv directory. Thanks Enable NFO Metadata Saver in library settings, Refresh Metadata.
mixXxim 2 Posted February 27, 2022 Posted February 27, 2022 Hi, Thanks for your answer. I have done it now. Does this also apply to existing content in the library? Or only for newly added content. Can a new scan of the library write existing content to an nfo? Thanks
GrimReaper 4926 Posted February 27, 2022 Posted February 27, 2022 1 minute ago, mixXxim said: Does this also apply to existing content in the library? Or only for newly added content. Can a new scan of the library write existing content to an nfo? 19 hours ago, GrimReaper said: Enable NFO Metadata Saver in library settings, Refresh Metadata. For existing content, Refresh Metadata is needed, simple scan won't do; if you don't perform metadata refresh, it'll apply on new content only, going onwards.
mixXxim 2 Posted February 27, 2022 Posted February 27, 2022 Hi, Thank you very much, that sheds some light in the dark. Another question...does the metadata scan then have to be carried out with "update ALL metadata" or "only missing metadata". Thanks
GrimReaper 4926 Posted February 27, 2022 Posted February 27, 2022 "Search for missing" should suffice.
