Brailyn 0 Posted February 17, 2022 Posted February 17, 2022 Running Emby for Android 3.2.32 and not getting any playback controls for music. The tablet is actually a head unit built into a vehicle so is permanently in landscape mode. I removed the app, cleared cache and storage and same issue. Is there some log files I could get for someone to help diagnose this issue a bit? Any help with this would be greatly appreciated!
Luke 42243 Posted February 17, 2022 Posted February 17, 2022 Hi, where do you not get controls? What device and version of Android?
Brailyn 0 Posted February 21, 2022 Author Posted February 21, 2022 @Luke I can play music, but after selecting a track there are no controls or any way to open up now playing menu. Android 10. Model UMS512_1H10_NATV. Resolution 1280x720. Emby for Android 3.2.32. Emby Server 4.6.7.0
Luke 42243 Posted February 21, 2022 Posted February 21, 2022 1 hour ago, Brailyn said: @Luke I can play music, but after selecting a track there are no controls or any way to open up now playing menu. Android 10. Model UMS512_1H10_NATV. Resolution 1280x720. Emby for Android 3.2.32. Emby Server 4.6.7.0 Hi, no controls where exactly?
Brailyn 0 Posted February 21, 2022 Author Posted February 21, 2022 (edited) @Luke There are no controls that come up on the bottom of the screen when music is playing. The only way to stop it is to play a video or force close Emby. I attached some screenshots of another Emby client showing what is missing. Missing playback bar: Missing menu--I cannot get here as the playback bar is missing. Edited February 21, 2022 by Brailyn
Luke 42243 Posted February 22, 2022 Posted February 22, 2022 OK, we're working on getting a new app update out, but in the meantime you can try sideloading the latest build and see if that helps: https://emby.media/emby-for-android.html Thanks.
Brailyn 0 Posted March 3, 2022 Author Posted March 3, 2022 @Luke updated just now to 3.2.40 and looks like there is a way to open the music menu now. Thanks!
