LuizFilmes 0 Posted February 16, 2022 Posted February 16, 2022 live tv he leaves alone after a while watching back to play screen
Luke 42243 Posted February 16, 2022 Posted February 16, 2022 Hi there, let's look at an example: Thanks !
Luke 42243 Posted February 16, 2022 Posted February 16, 2022 22 minutes ago, LuizFilmes said: ok embyserver.txt 46.01 MB · 0 downloads Hi, at what time did you start playing, and at what time did the problem occur? 1
LuizFilmes 0 Posted February 16, 2022 Author Posted February 16, 2022 I don't remember the right one but I can wait for the error to happen again and send another log here in this same post, can it be?
Luke 42243 Posted February 16, 2022 Posted February 16, 2022 4 minutes ago, LuizFilmes said: I don't remember the right one but I can wait for the error to happen again and send another log here in this same post, can it be? That would be great, thanks. 1
ebr 16335 Posted February 16, 2022 Posted February 16, 2022 Hi. Please also confirm whether or not you have the "Are you still watching" feature enabled on whatever client/app you were using. 1
Luke 42243 Posted February 18, 2022 Posted February 18, 2022 On 2/16/2022 at 5:57 PM, LuizFilmes said: new againembyserver.txt Hi @LuizFilmes do you have the "are you still watching feature" enabled in the app's settings? 1
LuizFilmes 0 Posted February 18, 2022 Author Posted February 18, 2022 (edited) Yes Edited February 18, 2022 by LuizFilmes
LuizFilmes 0 Posted February 18, 2022 Author Posted February 18, 2022 I disabled it and about duplicate movies is there any plugin that solves this?
Luke 42243 Posted February 23, 2022 Posted February 23, 2022 Looks like you're trying to delete a video but emby server does have access to delete your files. Can you take a look at this? 1
Luke 42243 Posted February 23, 2022 Posted February 23, 2022 You'd have to look at the folder permissions in Windows. Are the media folders read only? 1
Happy2Play 9812 Posted February 24, 2022 Posted February 24, 2022 8 hours ago, Luke said: You'd have to look at the folder permissions in Windows. Are the media folders read only? 9 minutes ago, LuizFilmes said: Yes If your media is Read only then Emby will not be able to Delete. As for duplicate media, do you have multi-versions of those files? If so how are they organized and named? But there is a plugin if you do not conform to Emby multi-version organization/naming scheme. automatic-version-grouping-for-movies See Multi-version movies section
