pat66655 3 Posted February 15, 2022 Posted February 15, 2022 Hello, i have an Amazon fire tv Stick 4K and the emby app. I tried to play 4K HDR10 movies, but it doesn't work. The emby Server shows that the movie is playing directly without any transcoding. On the fire tv Stick, i only get a black screen. Have anyone an idea how i get this thing working? Best regards Pat
GrimReaper 4898 Posted February 15, 2022 Posted February 15, 2022 Hey up, see: Additionally, you can submit in-app logs: Quote Emby for Android TV/Fire TV and Emby for Roku Logs These apps have the option to send an app log to us electronically. You enter the settings page and turn on the "Debug Options". Now there will be a new tile on your home page settings row (or menu option on the user menu at the top) labelled "Send Log". Reproduce your problem and then use this button to send the log. Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time
pat66655 3 Posted February 15, 2022 Author Posted February 15, 2022 Yes, the TV supports HDR10. On my Smartphone it works without any problems and without transcoding.
ebr 16337 Posted February 15, 2022 Posted February 15, 2022 38 minutes ago, pat66655 said: On my Smartphone it works without any problems and without transcoding. Okay, but that is a completely different device. Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
pat66655 3 Posted February 15, 2022 Author Posted February 15, 2022 Yes of course. I will do this tomorrow 1
pat66655 3 Posted February 16, 2022 Author Posted February 16, 2022 I tried to play the 4k HDR films with Plex on the fire tv. it worked straight away with no problems. I will generate the logs from emby today in the evening. 1
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 Hello, I was able to narrow down the problem now. It's the audio tracks. DTS-HD audio tracks now work. I have the DTS passthrough option for that and DTS-HD passthrough disabled. With the EAC3 8-channel audio tracks, it starts to jerk. Is there a way to force the EAC3 8 channel audio tracks to be transcoded into a different format?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 Little Update: when I start playback correction, the movies work
ebr 16337 Posted February 17, 2022 Posted February 17, 2022 Hi. Did you do this? On 2/15/2022 at 10:56 AM, ebr said: Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 Not yet. I will try to deliver it today 1
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 (edited) Ok, i have send the debug log from the firetv and here is my embyserver log. There is no transcoding or remux log. embyserver.txt Edited February 17, 2022 by pat66655
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 And here are the logfile when i use the playback correction mode. Then the movie will be played. ffmpeg-remux-4689d385-a965-406f-b293-b3036ba95c78_1.txt embyserver with correction mode.txt
ebr 16337 Posted February 17, 2022 Posted February 17, 2022 Hi. If you disable the PGS subtitles, does it play smoothly?
ebr 16337 Posted February 17, 2022 Posted February 17, 2022 You said if you select the DTS track, it does play smoothly?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 when I select the DTS audio track, it plays smoothly. if I select the eac3 audio track, it only plays smoothly with the playback correction
ebr 16337 Posted February 17, 2022 Posted February 17, 2022 Can you try sideloading this app on the device and see if it has the same issue?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 unfortunately no change from before
Luke 42245 Posted February 17, 2022 Posted February 17, 2022 13 minutes ago, pat66655 said: unfortunately no change from before What version did you try?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 I installed the apk from the link listed above. however, the user interface is not optimized for firetv.
Luke 42245 Posted February 17, 2022 Posted February 17, 2022 12 minutes ago, pat66655 said: I installed the apk from the link listed above. however, the user interface is not optimized for firetv. HI, why do you think that it isn't optimized for firetv?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 because it is an Android app for smartphones and tablets and not for firetv. the user interface is secondary to my problem. It doesn't work with the newer version either. EAC3 8ch audio tracks are not played back and it jerks a lot, although directplay is shown in the statistics view.
Luke 42245 Posted February 17, 2022 Posted February 17, 2022 15 minutes ago, pat66655 said: because it is an Android app for smartphones and tablets and not for firetv. the user interface is secondary to my problem. It doesn't work with the newer version either. EAC3 8ch audio tracks are not played back and it jerks a lot, although directplay is shown in the statistics view. Actually it's for all devices, including TV devices. What is the issue with the user interface?
pat66655 3 Posted February 17, 2022 Author Posted February 17, 2022 My problem is not about the user interface but about playing 4k media with EAC3 8ch audio tracks. but still briefly to the user interface. the letter bar in the films is missing. the keypad is not called up when a password or other entries are made.
