testor 1 Posted February 14, 2022 Posted February 14, 2022 Under Television trying to add Adam 12 all 7 seasons Emby puts them in one folder marked season 12?? it contains 7 #1s 7#2s all the way to 26 i have them labeled proper S01E02 Emby installed my NCIS all 19 seasons with no problem Just cant get this Plex installs it no problem (In process switching from Plex to Emby)
GrimReaper 4854 Posted February 14, 2022 Posted February 14, 2022 Can you show your folder structure?
Solution GrimReaper 4854 Posted February 14, 2022 Solution Posted February 14, 2022 (edited) 14 minutes ago, testor said: Here they are Remove "-" between "Adam-12" and "Season". Or "Adam-12-" altogether, leave only "Season"(s) xy, either will do. Edit: Nope, guess that 12 is confusing parser, leave only "Season"(s). Edited February 14, 2022 by GrimReaper Append
testor 1 Posted February 14, 2022 Author Posted February 14, 2022 Thank you for your help All fixed 1
