AcidRainX 0 Posted February 14, 2022 Posted February 14, 2022 Hi! I'm new in Emby, and I'm absoluetly beginner in bash... But, maybe someone can help me, o better, some has a example for bash (curl?) for this: I am trying to make a bash script for getting active users (currently logged in / last activity within last 20 minutes) from Emby? It's for a script for Unraid, for helping not going to standby if a user is logged / had an activity wihtin the last 20 (or variable) minutes. Would be nice, if this is working / authenticating in Emby an api key... @chef best regards
chef 3811 Posted February 14, 2022 Posted February 14, 2022 (edited) You probably want to access two different end point. "/sessions" will give you all the current session data, such as users, clients, now playing, etc. The other ebdpoint you want to access is the "/users" endpoint This will give you user data. When you access sessions you will get limited user data for that session. But you can extended the data, by getting the "userId" from sessions, and then requesting "/users/{userId}". That should return last active date etc. You'll need an API key if you are not building a client object. You can create an API key in the dashboard, and use "&api_key=" (or something similar to that). Edited February 14, 2022 by chef 1
chef 3811 Posted February 14, 2022 Posted February 14, 2022 I should also mention that just requesting "/users" will return all the user data. You could then iterate the json and find the user by name.
requa3r0 12 Posted December 3, 2022 Posted December 3, 2022 (edited) @AcidRainX I am trying to do the exact same thing. But I have no idea how the API works. Did you solve it, and Can you post a snippet of code that pull the information if a user is logged in on the server. Thanks. Edited December 3, 2022 by requa3r0
Luke 42234 Posted December 4, 2022 Posted December 4, 2022 Hi, have you taken a look at this to help get started? https://github.com/MediaBrowser/Emby/wiki
requa3r0 12 Posted December 4, 2022 Posted December 4, 2022 Hi @Luke Thanks for trying to point me in the right direction - but its not really helpful. I have been down that road an given up completely. The API makes no sense to me NB: If I go to the API from dashboard i am redirected to https://swagger.emby.media/ with this error Failed to load API definition. Errors Fetch error NetworkError when attempting to fetch resource. http://192.168.1.100:8096/emby/openapi?serverUrl=http%3A%2F%2F192.168.1.100%3A8096 Fetch error Possible mixed-content issue? The page was loaded over https:// but a http:// URL was specified. Check that you are not attempting to load mixed content. If i remove the S in https, I get the APIO webpage with a bunch of categories ActivityLogService ArtistsService AudioService BifService ETC But I have no idea where to find the necessary active user information. I looked under UserService And I can curl a list of users, but cannot differentiate if one is active or not. Can you perhaps give me the correct link, that I can use to curl to identify if someone/any user is logged in, for my power saver script on my server ;O) the API is beyond me to understand. All I need to know is if any user is logged in or not. Then Ill prevent the server standby until the next hour. Thanks for all you help.
chef 3811 Posted December 5, 2022 Posted December 5, 2022 (edited) If I may, You'll need an API key to do this. End you url request with "&api_key=", then put your key there. 1. Request /sessions If there are any open sessions, then you can assume that you have logged in user. To get users specifically that are logged in. Iterate the session object that is returned, and look for the "UserId" key in the JSON. The value will be their ID. To get further information about the currently logged in user make a new request to the server for each UserId you find. "Users/{userId}" This will return the full user object. Edited December 5, 2022 by chef
requa3r0 12 Posted December 22, 2022 Posted December 22, 2022 Thanks for your reply. @chef I do not fully agree with your assumption, or I misunderstand how to interpret the API 1. Request /sessions If there are any open sessions, then you can assume that you have logged in user. When I load the Sessions API with a token. and all users are logged out, I still have 2 active sessions 0: Seems to be the server session 1: is my Mobil phone where emby for android is logged in but not active 2: is my LG TV app also logged in but not active If I log in on chrome I get a 3 hit on the API request , but its similar to the 2 above. How do I distinguish between an inactive app user that is not logged out, and a user is actually logged in and actively browsing the emby server. This can not be done with the Sessions API. I see no difference on a inactive logged in app user, and an active one. The use-case is to prevent the server from sleeping, if you start browsing at 13:55 and then at 1400 the cron script check for server activity and network activity (with a 10mb threshold) to suspend if inactive. The server will suspend and kill the active session when the user is still just browsing..if a stream has been started, the network threshold is met and it will stay alive. I can not lower the treshold, then the server will not suspend, because there is always some traffic etc on a server that is not in use. Would be great if the APT could be used for this use-case. Can you make a specific API request just to return a boolean if any user is actually active.
chef 3811 Posted December 22, 2022 Posted December 22, 2022 (edited) Cool. The session object should have userId. You might be able to query lastActiveDate as well. Edited December 22, 2022 by chef
chef 3811 Posted December 22, 2022 Posted December 22, 2022 PXL_20221222_154138194.mp4 The one session is a logged in user session. I'm not sure the difference.
embylad892746 32 Posted June 2, 2023 Posted June 2, 2023 (edited) I just wrote a simple python script to check for any active emby users within the last 10 minutes. You just need to update the top 2 variables (api token and emby url). I call this script from my backup script, so that i can avoid shutting down all my docker containers while people are using emby. I don't bother with the Sessions endpoint as it's not needed. Simply checking the LastActivityDate works very effectively. import json import os import requests import dateutil.parser as dp from datetime import datetime, timedelta, timezone ''' Checks for any active emby users within last x minutes. Prints True if active users found, otherwise False. ''' api_token = "<api token>" emby_url = "<emby url>" endpoint = "Users" minutes = 10 url = os.path.join(emby_url, "emby", endpoint, "?api_key=" + api_token) headers = {'Accept': 'application/json'} response = requests.get(url, headers=headers) json_data = json.loads(response.text) now = datetime.now(timezone.utc) active_status = False for user in json_data: last_active = dp.isoparse(user["LastActivityDate"]) if now - timedelta(minutes=minutes) <= last_active <= now: active_status = True break print(active_status) Edited June 2, 2023 by embylad892746 2
embylad892746 32 Posted June 9, 2024 Posted June 9, 2024 (edited) Here's a slightly updated and cleaner version. Changes are: 1) exclude my own user from the calculation (i only care if others are active), 2) check that each user field has ["LastActivityDate"] key: i had a weird case once where it didn't exist (possibly for brand new user that hasn't signed in?) import json import os from datetime import datetime, timedelta, timezone import dateutil.parser as dp import requests def active_emby_users( api_token: str, hostname: str, my_username, minutes: int = 10 ) -> bool: """Determine if there are active emby users. Prints status to stdout. Args: api_token (str): emby api token hostname (str): hostname of emby server (e.g. https://example.com) my_username (str): Your username to exclude from active users check. Case sensitive. minutes (int, optional): The window to check for active users. Defaults to 10. Returns: bool: True if active users found, otherwise False """ url = os.path.join(hostname, "emby", "Users", "?api_key=" + api_token) headers = {"Accept": "application/json"} response = requests.get(url, headers=headers) json_data = json.loads(response.text) now = datetime.now(timezone.utc) active_status = False for user in json_data: if user["Name"] == my_username: continue if "LastActivityDate" in user: last_active = dp.isoparse(user["LastActivityDate"]) if now - timedelta(minutes=minutes) <= last_active <= now: active_status = True break print(active_status) return active_status if __name__ == "__main__": ############################ api_token = "<api token>" hostname = "<hostname>" minutes = 10 my_username = "<username>" ############################ active_emby_users(api_token, hostname, my_username, minutes) Edited June 9, 2024 by embylad892746 1
