terry@tadbs.com 0 Posted February 13, 2022 Posted February 13, 2022 Having the same problem. Tried the same approach as above by selecting the first three of a zip code 926 for USA California and it keeps replying try again.
terry@tadbs.com 0 Posted February 13, 2022 Author Posted February 13, 2022 There was an error downloading tv lineups for hdhomerun. This was working for the past years.
terry@tadbs.com 0 Posted February 13, 2022 Author Posted February 13, 2022 Having this same problem today. What is the fix?
Carlo 4561 Posted February 14, 2022 Posted February 14, 2022 Hi, Since no one else is reporting issues of this nature it not likely a provider issue which would likely mean it's environmental or local to your server/lan setup. Can you post your server log file for us to get a look at?
Carlo 4561 Posted February 14, 2022 Posted February 14, 2022 Hi, as ebr mentioned we can't do much without having some additional information like the server log file to look at. Carlo
Luke 42237 Posted February 14, 2022 Posted February 14, 2022 @terry@tadbs.com I've merged your other identical postings into here. As the others have mentioned, please attach the emby server log from when you tried to do this. Thanks.
terry@tadbs.com 0 Posted February 14, 2022 Author Posted February 14, 2022 Here is the log from yesterday. embyserver3.txt
ebr 16332 Posted February 14, 2022 Posted February 14, 2022 Hi. Did you attempt to setup a tuner during that timeframe? I cannot find anything in the log that looks like that is the case.
terry@tadbs.com 0 Posted February 14, 2022 Author Posted February 14, 2022 Another attempt to add the guide. about 1:07PM today. embyserver1307setup .txt
Solution Luke 42237 Posted February 15, 2022 Solution Posted February 15, 2022 5 hours ago, terry@tadbs.com said: Another attempt to add the guide. about 1:07PM today. embyserver1307setup .txt 109.68 kB · 1 download @terry@tadbs.com it appears you configured a custom cache folder for the server that is no longer valid: System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path 'T:\Emby\Cache\cache\httpclient'. Try blanking out this option in Emby Server settings to reset it to the default value. Then try setting up guide data again and let us know if that helps. Thanks.
Carlo 4561 Posted February 25, 2022 Posted February 25, 2022 @terry@tadbs.com did you get a chance to try what Luke mentioned?
