Hispanico957 23 Posted February 12, 2022 Posted February 12, 2022 (edited) I have set properly emby server on my windows 11. Also i have dynamic ip and for this i have on DYNDNS (dyndns.it / dyndns-custom) my host: myname.homepc.it I try from outside lan with my phone and i can connect to emby server with myname.homepc.it port 8096, user and pass The problem is when on my computer enable VPN (NordVpn), always from ny phone is impossible connect to emby server Pls some suggestions Thank Hispa Edited February 12, 2022 by Hispanico957
GrimReaper 4927 Posted February 12, 2022 Posted February 12, 2022 NordVPN does not support Port Forwarding, which you would need to remotely access Emby server with VPN connection active. Do you offer port forwarding? | NordVPN Support 1
Hispanico957 23 Posted February 12, 2022 Author Posted February 12, 2022 1 minute ago, GrimReaper said: NordVPN does not support Port Forwarding, which you would need to remotely access Emby server with VPN connection active. Do you offer port forwarding? | NordVPN Support Thank understand. There is a vpn that not have this problem and i can use with emby? Thank Hispa
GrimReaper 4927 Posted February 12, 2022 Posted February 12, 2022 Just now, Hispanico957 said: Thank understand. There is a vpn that not have this problem and i can use with emby? Thank Hispa Yep, few of them, @cayars likes PIA, I prefer AirVPN, and surely there are others. 1
Carlo 4561 Posted February 12, 2022 Posted February 12, 2022 Nothing particularly special about PIA compared to other VPNs. Just a case of recommending what you're familiar with that should give reproducible experiences for others. I just happen to have used it for years and know it has all the features needed to work. It has good coverage and lots of servers for a pretty consistent experience. That surely doesn't mean it's the best for any particular user or geo area which would need private testing. 1
smatster 0 Posted May 7, 2022 Posted May 7, 2022 Was able to install OpenVPN Connect Follow guide but download OpenVPN Connect for internet blocking while VPN is down: https://support.nordvpn.com/Connectivity/Windows/1047409832/How-to-set-up-manual-connection-on-Windows-7-and-above.htm Relevant config file info (xxx.xxx.xxx is VPN subnet; yyy.yyy.yyy.yyy is router gateway): client dev tun proto tcp remote xxx.xxx.xxx.209 443 resolv-retry infinite remote-random route plex.tv xxx.xxx.xxx.212 yyy.yyy.yyy.yyy nobind tun-mtu 1500 tun-mtu-extra 32 mssfix 1450 persist-key persist-tun ping 15 ping-restart 0 ping-timer-rem reneg-sec 0 comp-lzo no remote-cert-tls server block-outside-dns Verified VPN IP and did DNSleak tests showing correct VPN IP address. Use at own risk.
marshallwyoung 5 Posted September 1, 2022 Posted September 1, 2022 (edited) If my emby server is on a pc running a vpn, will it route all traffic through the internet or does it remain local? Edited September 1, 2022 by marshallwyoung
Luke 42289 Posted September 1, 2022 Posted September 1, 2022 1 hour ago, marshallwyoung said: If my emby server is on a pc running a vpn, will it route all traffic through the internet or does it remain local? Re:
