kodiak437 5 Posted February 12, 2022 Posted February 12, 2022 Hello, I just recently updated by cert (as i do every year) but for some reason i cant get Emby to startup with https. The cert is working on my proxy also so dont think its an issue with the file. I have some resources that bypass the proxy external so need the https for that. I have recreated the cert about 5 times now but still see errors in the logs each time. Created .pfx with and without password different names and anything else i can think of but it wont start. Thanks in advance for your help.. This is the error its throwing: 2022-02-11 19:24:10.335 Error App: Error loading cert from /mnt/200TB/emby/server/certs/NewCert/wonk4.pfx *** Error Report *** Version: 4.6.7.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.19.0-8-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.98-1 (2020-01-26) Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 32 Data path: /var/lib/emby Application path: /opt/emby-server/system Interop+Crypto+OpenSslCryptographicException: Interop+Crypto+OpenSslCryptographicException: error:2006D002:BIO routines:BIO_new_file:system lib at Interop.Crypto.CheckValidOpenSslHandle(SafeHandle handle) at Internal.Cryptography.Pal.OpenSslX509CertificateReader.FromFile(String fileName, SafePasswordHandle password, X509KeyStorageFlags keyStorageFlags) at System.Security.Cryptography.X509Certificates.X509Certificate..ctor(String fileName, String password, X509KeyStorageFlags keyStorageFlags) at System.Security.Cryptography.X509Certificates.X509Certificate2..ctor(String fileName, String password) at Emby.Server.Implementations.ApplicationHost.GetCertificate(CertificateInfo info) Source: System.Security.Cryptography.X509Certificates TargetSite: Void CheckValidOpenSslHandle(System.Runtime.InteropServices.SafeHandle)
Q-Droid 1011 Posted February 12, 2022 Posted February 12, 2022 Check the ownership/permissions of the .pfx file and make sure emby can read it.
kodiak437 5 Posted February 14, 2022 Author Posted February 14, 2022 Thanks Q-Droid, i didn't check that and yes that's what it was.. I was pulling the certs from my proxy and forgot to change. Duhh.. Appreciate the help! 1
