Charles Bosquet 0 Posted February 10, 2022 Posted February 10, 2022 Hello Vic and thank you again! How can I have under the post the "critical Rating" and "Parental Raiting" field, I saw it on other user screenshots but I only see the "Genres" field. If I had the information at this level, it would be very useful for me to sort out the programs to be cleaned. Thanks again!
VicMoore 755 Posted February 10, 2022 Author Posted February 10, 2022 Well, I fixed one problem and introduced another. The back button stopped hiding the metadata editor. The code below fixes this problem. Vic emby_new_tool_9_a.html
VicMoore 755 Posted February 10, 2022 Author Posted February 10, 2022 Hello Charles... A better way to do what you want is to filter on minimum parental rating, or max parental rating, then select all of the filtered items (shift-click) and use the editor to change all of their parental ratings at once. Vic
VicMoore 755 Posted February 11, 2022 Author Posted February 11, 2022 I corrected a simple bug when you return from a page that has been filtered. If anyone is having problems, please let me know. Vic emby_new_tool_10.html
VicMoore 755 Posted February 12, 2022 Author Posted February 12, 2022 GrimReaper, Thanks so much for starting this new forum for me. The latest code is attached below. emby_new_tool_11.html 1
VicMoore 755 Posted February 15, 2022 Author Posted February 15, 2022 Attached below is the latest code. I fixed a number of bugs and added an audio player to the web client. Vic emby_new_tool_13.html
VicMoore 755 Posted February 16, 2022 Author Posted February 16, 2022 I cleaned the code up, fixed a few gui bugs, and improved the metadata editor. I still need to do more testing. vic emby_new_tool_14.html
VicMoore 755 Posted February 17, 2022 Author Posted February 17, 2022 (edited) Attached is the latest code. I added the ability to change the Primary images. Vic emby_new_tool_15.html Edited February 18, 2022 by VicMoore
VicMoore 755 Posted February 19, 2022 Author Posted February 19, 2022 Horstepipe, the code is below. I implemented it in the new tool. I will put it into the other tool tomorrow. I did a few tests and it worked great. You just define a filter and apply it. Let me know if you have a problem. Vic emby_new_tool_16.html
VicMoore 755 Posted February 28, 2022 Author Posted February 28, 2022 (edited) In this version there are lots of changes. First, you can now filter on video type, such as 4k, 3D, HD, DVD, ISO, etc. MangoMC requested this feature and Happy2Play showed me how to do this via the Emby API. Another change is that the options for saving tag, prople, studio, and genre metadata have been increased. You can now add just new metadata to other selected files rather than all of the metadata. For example, if you add the tag ZZZ to one selected item, you can save just that tag to all of the other selected items, without deleting any of their current tags. Horstepipe identified this deficiency and brought it to my attention. I would appreciate all bug reports so I can fix them ASAP. Horstepipe, please test this code to make sure it works as you expect. Also look at my wording on the radio button options to determine if they convey the expected meaning. Vic emby_new_tool_19.html Edited March 11, 2022 by VicMoore
VicMoore 755 Posted April 17, 2022 Author Posted April 17, 2022 (edited) Latest Tool emby_new_tool_28.html Edited June 3, 2022 by VicMoore
Matot 2 Posted June 19, 2022 Posted June 19, 2022 Hi Vic, Really Great tool, thank you, but i have a problem, ,can you help me ? By error, in "Genre Section" i check the" lock" box for all my 1200 movies. I would like to unlock now all my movies genre but i can't do it with bulk edit. i have to go one by one to uncheck the box. Can't you add a new check box like "unlock" for the bulk Edit ? Sorry for my bad englsh, i'm french ....
denzoid 57 Posted June 24, 2022 Posted June 24, 2022 I am looking for a way to bulk add/edit "Lock this item to prevent future changes" which appears on each individual movie's metadata page and can (apparently) be done on a Windows Emby Server via the built-in Metadata manager but I run my Emby server on Unraid in a Docker container so that feature is missing. Is there a way to do this with this tool?
GrimReaper 4895 Posted June 24, 2022 Posted June 24, 2022 3 minutes ago, denzoid said: I am looking for a way to bulk add/edit "Lock this item to prevent future changes" which appears on each individual movie's metadata page and can (apparently) be done on a Windows Emby Server via the built-in Metadata manager but I run my Emby server on Unraid in a Docker container so that feature is missing. Nope, bulk editing feature is not available in any server platform. That said, yes, you can bulk add/remove locks via @VicMoore's extremely useful tool (although he's a bit lenient to keep his two tools separate in their respective thread, eh, Vic ), latest version of which you can find here:
DJMonty 1 Posted January 6, 2023 Posted January 6, 2023 Love this tool - but wondering if there is any way to filter by Studio? I'm trying to clean up this field and am not enjoying going through each film one by one and checking. :)
VicMoore 755 Posted April 4, 2023 Author Posted April 4, 2023 Sorry, I have been ignoring this forum - I have been trying to move the tool to a plugin. The plugin is called Bulky. I will get back to this forum soon. Vic
rbjtech 5341 Posted April 4, 2023 Posted April 4, 2023 39 minutes ago, VicMoore said: Sorry, I have been ignoring this forum - I have been trying to move the tool to a plugin. The plugin is called Bulky. I will get back to this forum soon. Vic https://emby.media/community/index.php?/topic/117487-bulky-bulkmass-metadata-editor/
