howieT82 2 Posted February 11, 2022 Posted February 11, 2022 Hello how do I go about correcting a folder or files that have the wrong info if I try to identify manually, I’m not seeing the correct episode, tv show, or movie also if something is incorrectly identified how do I remove it or change it thanks
rbjtech 5345 Posted February 11, 2022 Posted February 11, 2022 (edited) Use the 'Identify' option on the ... menu for each item to re-identify it. If you have a hard time getting it to identify items - then go to thetvdb or tmdb, find the item manually and take a note of the actual Id - which you can then use in the 'identify' screen. lastly - you can actually add the id into the foldername to directly force it it use that identify :- \Independence Day (1996) [tmdbid=602]\ \Reacher (2022) [tvdbID=366924]\ for example.. Edited February 11, 2022 by rbjtech
visproduction 338 Posted February 11, 2022 Posted February 11, 2022 Just a guess try 2 Guns (2013) BlueRay - 1080P or 2 Guns (2013) - 1080P
rbjtech 5345 Posted February 11, 2022 Posted February 11, 2022 23 minutes ago, visproduction said: Just a guess try 2 Guns (2013) BlueRay - 1080P or 2 Guns (2013) - 1080P ? This was my example to the OP ...
howieT82 2 Posted February 11, 2022 Author Posted February 11, 2022 1 hour ago, rbjtech said: Use the 'Identify' option on the ... menu for each item to re-identify it. If you have a hard time getting it to identify items - then go to thetvdb or tmdb, find the item manually and take a note of the actual Id - which you can then use in the 'identify' screen. lastly - you can actually add the id into the foldername to directly force it it use that identify :- \Independence Day (1996) [tmdbid=602]\ \Reacher (2022) [tvdbID=366924]\ for example.. So add the IMDb Id to the identification tab
Happy2Play 9814 Posted February 12, 2022 Posted February 12, 2022 Can you go over a specific example? To include naming scheme and structure.
