Eisi2005 14 Posted February 11, 2022 Posted February 11, 2022 Hello, I would like to synchronize another user with trak.tv. I then selected his user name in the Trakt plugin, had me given a pin and entered it. As I understand it, a token is generated from the pin the first time it is called, but unfortunately that doesn't work. Existing users will continue to be synchronized. I have already uninstalled the plugin and deleted the trak.xml from the config directory. Now the old users are no longer synchronized Here is an excerpt from the log. 2022-02-11 13:30:00.001 Info HttpClient: POST https://api.trakt.tv/oauth/token 2022-02-11 13:30:00.174 Error Trakt: Exception handled *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.10.19-Unraid (root@Develop) (gcc (GCC) 9.3.0, GNU ld version 2.33.1-slack15) #1 SMP Sat Feb 27 08:00:30 PST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadRequest at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.RefreshUserAuth(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SetRequestHeaders(HttpRequestOptions options, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.GetFromTrakt(String url, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendGetAllWatchedMoviesRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncFromTraktTask.SyncTraktDataForUser(User user, Double currentProgress, CancellationToken cancellationToken, IProgress`1 progress, Double percentPerUser) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2022-02-11 13:30:00.177 Error Trakt: Error syncing trakt data for user xxxx *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.10.19-Unraid (root@Develop) (gcc (GCC) 9.3.0, GNU ld version 2.33.1-slack15) #1 SMP Sat Feb 27 08:00:30 PST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadRequest at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.RefreshUserAuth(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SetRequestHeaders(HttpRequestOptions options, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.GetFromTrakt(String url, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendGetAllWatchedMoviesRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncFromTraktTask.SyncTraktDataForUser(User user, Double currentProgress, CancellationToken cancellationToken, IProgress`1 progress, Double percentPerUser) at Trakt.ScheduledTasks.SyncFromTraktTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Have anyone a hint ?
Luke 42255 Posted February 15, 2022 Posted February 15, 2022 Hi @Eisi2005 are you still running into this?
sysdruids 0 Posted February 18, 2022 Posted February 18, 2022 I have 2 new emby setups, 2 different servers just to test this. fresh installs, little media, just in case. Tried it on different ISPs, on both machines there is a bash script that backups my trakt to a csv and it works on both. I have deleted the trakt.xml, restartted, reinstalled... the works. The result is always the same: 2022-02-18 17:16:40.275 Error Trakt: Exception handled *** Error Report *** Version: 4.6.7.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.13.0-27-generic (buildd@lgw01-amd64-045) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #29~20.04.1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) at Trakt.Api.TraktApi.GetFromTrakt(String url, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendGetPlaybackShowsRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncFromTraktTask.SyncTraktDataForUser(User user, Double currentProgress, CancellationToken cancellationToken, IProgress`1 progress, Double percentPerUser) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2022-02-18 17:16:40.277 Error Trakt: Error syncing trakt data for user blacksmiths *** Error Report *** Version: 4.6.7.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.13.0-27-generic (buildd@lgw01-amd64-045) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #29~20.04.1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) at Trakt.Api.TraktApi.GetFromTrakt(String url, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendGetPlaybackShowsRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncFromTraktTask.SyncTraktDataForUser(User user, Double currentProgress, CancellationToken cancellationToken, IProgress`1 progress, Double percentPerUser) at Trakt.ScheduledTasks.SyncFromTraktTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: Emby.Server.Implementations TargetSite: Void MoveNext()
Luke 42255 Posted February 18, 2022 Posted February 18, 2022 Please attach the complete server log. thanks.
sysdruids 0 Posted February 21, 2022 Posted February 21, 2022 Hello, sorry forthe delay, I wasaway for the weekend. Here's the log, I did a restart and forced the. import playstates from trakt at timestamp: 2022-02-21 10:11:36.237 Thank you embyserver.txt
Luke 42255 Posted February 23, 2022 Posted February 23, 2022 Hi, can try again and let us know how it compares? Thanks.
sysdruids 0 Posted March 7, 2022 Posted March 7, 2022 Hi. did it a couple of times. Same result embyserver.txt
Luke 42255 Posted March 10, 2022 Posted March 10, 2022 On 3/7/2022 at 4:03 AM, sysdruids said: Hi. did it a couple of times. Same result embyserver.txt 40.03 kB · 0 downloads Are you behind a VPN?
sysdruids 0 Posted March 14, 2022 Posted March 14, 2022 Hello. No, no VPN and on different (internet) locations. My account still works with the backup scripts (that uses the API) I normally use
Luke 42255 Posted March 14, 2022 Posted March 14, 2022 OK, we're soon to release Emby Server 4.7 so I would suggest re-evaluating with that once available. Thanks.
sysdruids 0 Posted March 14, 2022 Posted March 14, 2022 Sure, I did had a workaround to fix it on the second server, for prosperity: Kodi companion + Kodi + Kodi embycon + Kodi Trakt plugin. It is working for my better half usage and accunt.
StevenDTX 15 Posted June 20, 2022 Posted June 20, 2022 I discovered this week that my Emby server hasn't scrobbled anything to Trakt since back in April. I have removed the plugin, reinstalled, reauthorized...the whole nine yards. I still get the same error: 2022-06-20 18:43:55.618 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2022-06-20 18:43:56.213 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2022-06-20 18:43:56.780 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2022-06-20 18:43:56.851 Error TaskManager: Error *** Error Report *** Version: 4.7.4.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.46-Unraid (root@Develop) (gcc (GCC) 11.2.0, GNU ld version 2.37-slack15) #1 SMP Fri Jun 10 11:08:41 PDT 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Locked at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) at Trakt.Api.TraktApi.GetFromTrakt(String url, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SendGetAllWatchedMoviesRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncMovies(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncUserLibrary(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: Emby.Server.Implementations TargetSite: Void MoveNext() embyserver - trakt-error.txt
StevenDTX 15 Posted June 21, 2022 Posted June 21, 2022 (edited) I also cannot seem to be able to enable debug logging for the Trakt plugin. https://i.imgur.com/jQnppGB.mp4 Edited June 21, 2022 by StevenDTX
Luke 42255 Posted July 2, 2022 Posted July 2, 2022 On 6/20/2022 at 7:47 PM, StevenDTX said: I discovered this week that my Emby server hasn't scrobbled anything to Trakt since back in April. I have removed the plugin, reinstalled, reauthorized...the whole nine yards. I still get the same error: 2022-06-20 18:43:55.618 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2022-06-20 18:43:56.213 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2022-06-20 18:43:56.780 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2022-06-20 18:43:56.851 Error TaskManager: Error *** Error Report *** Version: 4.7.4.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.46-Unraid (root@Develop) (gcc (GCC) 11.2.0, GNU ld version 2.37-slack15) #1 SMP Fri Jun 10 11:08:41 PDT 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Locked at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) at Trakt.Api.TraktApi.GetFromTrakt(String url, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SendGetAllWatchedMoviesRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncMovies(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncUserLibrary(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: Emby.Server.Implementations TargetSite: Void MoveNext() embyserver - trakt-error.txt 30.97 kB · 0 downloads Hi @StevenDTX looks like Trakt has locked your account. You'll need to submit a ticket to Trakt support to have them unlock it for you. Please let us know if this helps. Thanks.
